Need help. Cannot start os engine
Os tz spec ii
I just got a used os tz spec 2 from ebay.
No luck.. I can't start the engine.
I suspect my needle setting is incorrect.
Pls advise the default needles setting. So that I can get a starting pt.
Thx
Thx
Here is the best I could find on it.
High Speed Needle (HSN) 2 turns out from closed.
Low Speed Needle (LSN) close it fully (with carb open, so as not to damage the main jet), teh open it until it is flush with the slide body.
Main Jet Needle or Valve (MRN) has to be flush with carburator body, and leave it there and never touch it again.
Idle Speed Needle (ISN), close it until slide valve is open about 1mm, and then when engine has started and warmed enough readjust to a slow steady idle.
