"Challenge Formula One"
#256
I haven't seen double sided tape as stiff as the Tamiya stuff anywhere.
Saturday's F1 racing was great. Steve H. took the pole and the A-main win but Denmark, Casey and a host of others were in the A-main battle. Rod M. took the B-main over yours truly.
The B-main F1 video is the first video on the Frederick Hobbytown MD website and the A-main F1 racing starts at the 30 minute mark. check them out:
http://www.ustream.tv/recorded/12654699
The indoor temp was about 61 F and all the cars are running on rubber. I think the fast F1 lap was an 11.6, and it took 27 laps to make the A main.
more later.
more later.
#257
Pictures
FEB 12th, 2011 at the C......
#258
More Pics from from a few days ago....
#263
Front : ride hight as high as i can get it, gold springs. med compound rubbers camber at 0 1deg toe in on both front wheels
rear setup soft tplate with nuumber two bearing holders upside down for the highest ride hight soft rear tires trf center shock with white spring and 30wt losi oil.1oz of waight added to the diffuser.
battery 5000mah 30c flight max
esc speedpassions gt 1.1
motor is lrp x12 21.5
geting the exotek tomarrow and need to know what changes to make.
#264
F1 Stuff is not readily availble at my LHS. Granted there are two within an hour of me that will gladly order anything that I want, but I was wondering where you guys are buying from and if possible is there one site that has loads of links to other places that sell F1 stuff. I dont mean to be giving Robk extra homework to do but it would be great to have an F1 specific source page.
#265
www.d-drivesportsenglish.com www.rcmart.com www.tqrcracing.com www.Muchbobby.com and others.
check with T.marshal here. He is putting something together to get U.S. drivers what they need as well.
#266
rubber tires on very bumpy low bite ashpalt. here is my current non exo setup
Front : ride hight as high as i can get it, gold springs. med compound rubbers camber at 0 1deg toe in on both front wheels may want to try the black front spring
rear setup soft tplate you may want to try the t plate with the u shaped cutoutwith nuumber two bearing holders upside down for the highest ride hightgo to lowest rear the car will tolerate and not bounce soft rear tires trf center shock with white springget the softest spring you can, try the mini cooper springs and20-25 30wt losi oil.1oz of waight added to the diffuser.
#267
News flash: Triple A mains next week
At The Coliseum, just announced triple A mains next week, three rounds of qualifying starting at Noon!
#268
big battles today between exotec's, tamiya's and the tight twisty track. No idea who or what will prevail in the A-main as such different cars are atvtge front. Steve's F 104 is top of the TCS legal cars.
