"Challenge Formula One"
#226
12 years
The F104 is an incredible platform. It is long and narrow like a modern F1 car. Tamiya is primarily a model company so it is in order that they are going for the scale look as much as possible. The Dif is very good now and the front end is so much more workable. I think we have to get past the idea of it being new and an upgrade, and see it as new and different. I need to make an increase in my pace, but I still hope more guys come out for the TCS. it already looks like 2 heats.
As for the New 1/1 F1 cars, Sauber have something going on up front again. From the team that gave us the twin keel front end. More or less, this is Ramph's last car and I am sure he really did some thinking. So far nothing really radical from the other teams. I am sure Mclaren have the Q(quick) duct this year
J
J
#227
Thursday Free At The C
On another thread, several people plan to go Coliseum for a free run. Anyone here planing on going?
J
J
#229
#230
This may seem silly but has anyone tried to take out the front drive shafts of an F201 and run it as rear wheel drive only? Any setup tips?
#231
Yes, the front drive shaft can be removed and the car run as 2 wheel drive, but it is not seen very often.
The relative complexity of the F201 makes for a wonderful car with fully independent suspension, but it takes ample spare parts to keep the car running as accidents happen.
It can be a lot of fun wrenching on that car, adjusting suspension travel, linkages, differentials, etc. and some 4WD racers really enjoyed it.
I never raced mine on purpose with 2WD, but a few times my front diff was loose. Sometime even the rear diff would come loose and the car would be front wheel drive. That was interesting.
#232
To make an F201 RWD only, you'll want to not only pull the front driveshaft, but also the front dogbones (or cvd's if you have them) and the front differential. At first I tried doing this by only pulling the front driveshaft, leaving the dogbones and front diff installed. Bad idea, the car didn't do much other than burnouts and spinouts. With the front diff still acting on the front wheels with no power being applied to them, it essentiall "ties" the front wheels together and doesn't let the car turn, and when it does, it swaps ends.
You could just pull the front dog bones and leave the diff and center driveshaft, but it removes alot more weight taking it all out. (its rotating mass)
Tires and your running surface make the biggest difference in RWD. I'd recommend soft springs in the rear to help give it rear grip. It may understeer at first, but it will be driveable and you can tune from there. Don't go to aggressive with the camber, i'd suggest -1 degree in the rear and -2 up front, max. You'll get funny tire wear with more camber.
Hope it helps Wish I could help more, but I returned my F201 to shelf queen duty after my F104 pro arrived and havent looked back. For all the beauty of the F201 chassis, the suspension mounting points on the front bulkhead/diff case don't hold up well to impacts, even with the lower reinforcing piece.
Enjoy
Jeff
#233
#235
Spool
Why not run a spool instead of just 2wd?
#236
Thanks for all the replies and tips. My club rules is that we can run any F1 style car as long as it is rear wheel drive only. It makes for an interesting combo because the track is extremely slippery at the best of times.
I also decided to run this car because it just looks great also I like the idea of push rod suspension. Fortunately, I have way too many spare parts and hop ups (back from the TCS days) so it seemed like a shame to let it all go to waste.
I am also running the 3 racing chassis now and while its fantastic that chassis variables have been eliminated, it really highlights how badly the car is weighed down on the right rear because of the motor. I think I need to have a look at a combination of droop and spring preload to sort this out.
I'll post an update on setup when I get it sorted out.
#237
Left, right, go and whoa. Anything beyond that is too much science.
#238
Long and Narrow
Well. Mclaren, have stayed long, but gotten thinner. The bulge under the Airbox is interesting. It looks like the F104 was made for this. Any comments on the Renault/Mclaren Airbox? I think they are trying to control the air flow rate on the diffuser. If we could only do that on our little cars.......
#239
hmmm. new F1 cars are popping up everywhere. Didn't the groundhog say we had to wait a while longer for spring? And some of those designs, shapes, and color schemes...are they the result of natural selection or too much in-breeding?
#240
Older F1 Challenge?
Racers,
let's go old school. We now have enough body sets on the way to do do a retro grand prix. http://tamiyablog.com/wp-content/upl...g-2011-010.jpg I hope we get the Tyrell 019 next...
