Fuel Tank Air Bubbles >
Old 09-30-2010, 12:57 PM
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default Fuel Tank Air Bubbles
Was tuning my engine for this Sundays big race replaced all the fuel hoses with clear as I was tuning noticed small bubbles passsing through the fuelline into the Carb.
Pulled my tank submerged into water holding hoses plugged one hose and blew no bubbles in the water.
Having bubbles in the fuel line when motor is running is that normal???
Clunker wasnt exposed to air tank was full
bigjayjay1 is offline
Old 09-30-2010, 01:00 PM
Suspended
Trader Rating: 202 (96%+)
i have never noticed it in mine, you could try putting a longer pressure line on about a inch longer than fuel line
inferno13 is offline
Old 09-30-2010, 01:16 PM
n.e.r.d's Avatar
Are you running a fuel filter?
If yes, the filter might be the cause of the bubbles..
Remove it and you shld be good to go!
(do it at your own risk though.. then again nobody uses them anymore right?)
n.e.r.d is offline
Old 09-30-2010, 01:17 PM
stallen50's Avatar
Trader Rating: 30 (100%+)
+1 for what inferno said
stallen50 is offline
Old 09-30-2010, 03:19 PM
bigjayjay1's Avatar
no filter will try the longer piece never noticed since i always ran blue tube.
