Ofna Ultra GTP2e
#781
so i went and disassembled as much as needed. now the driveshaft will barely move and it is centered within the drive cup.
but the noise is still there...
#782
2 things.
1. anyone find a way to get rid of the steering slop? i swear. i have another ofna SCT and that has a similar slop. i can twist each front tire so it can go like +/- 2 degrees each way...
2. the front upper arms. they have those little clips to adjust caster. but on mine, there is just a tiny gap, maybe like 1/16" so that the arm can slide back and forth... i thought about buying like a thin enough washer, or maybe a set of those clips... but at $6 for a set of those... sigh...
On the steering some of it come from the steering post, there was a ball bearing kit for the ultra series, I got the part # from SNR #31130,
http://www.nitrohouse.com/advanced_s...ee3231fa967bfd
The rest comes from the endlinks themselves ,maybe a dubro ball end ?
The front upper arms, yes I put some clutch bell shim washers, that did the trick, I did the samething to the rear since I have the rear pbs and torsion swaybar on mine car, I also run the front lower pin arm holder in the rear,since I dont need adjust toe via the rear lower pin arm,this sets the pins up just like the front so you dont have that awkward angle and allows the pin to rotate for less binding in the suspension,PBS rear is so much better, car is way more planted,torsion swaybar is so much better also
#783
Anyone looking for a good well done up car, and a good deal.
Or if you know anyone looking for a Electric GT.
Check this out
http://www.rctech.net/forum/r-c-item...ml#post9191163
Check this out
#784
Check this out
Check this out
#785
#786
Here we GO! ... This is how we do it down in TAMPA FL. fellas!
http://www.youtube.com/watch?v=GdB_6S-lVyQ&NR=1
#787
%Tower finally got back to about special ordering the thunder tiger Subaru bodies.
If anyone is interested PM me and ill ask them about making multiple orders... say by the end of this week, like Friday...
I am writing in reference to your recent inquiry regarding special ordering the Thunder Tiger parts. The PD1792-Subaru Impreza clear body is $27.99, PD1793-Subaru Impreza Painted body set is $39.99 and PD1794-Impreza Clear Body with decal is $33.99. It is available for a special order and would cost $ plus any postage that the manufacturer may charge to us. All special orders must be placed on a credit card, are non-returnable and cannot be canceled once ordered. I do not have an estimated time of arrival from the manufacturer. Please let us know if you would like for us to place an order for you. We appreciate your time and your business with us.
#788
I just got a set of Ofna belted street tires for my Vorza. Can someone tell me whats up with the foams? It came with two strips of foam. I tried to get both of them inside the tire and it looked like the smaller foam was wadded up. I'm from offroad land so please excuse my ignorance of onroad products. I've been looking at these gtp3e's and I don't see how my fleet could go without one of these jewels! LOL Plus there's a onroad race track near by.
Jerry
Jerry
http://www.igthobbies.com/ALPHA-TIRES_c_245.html
#789
Get away from those tires and run these onroad pre-mounted tires.I run these on my Vorza and GTP2E.(soft compound is the best and they dont wear fast at all)
#795
sorry to step in but i have been checking around on the net and can not find a sure answer.
i have a ofna mbx from the ultra line...which the gpt is from the ultra line as well. i am wondering if i can buy a brushless kit that converts the gtp to electric using my buggy?
any help would be great. thanks arick
