Ofna Ultra GTP2e >
Ofna Ultra GTP2e
Ofna Ultra GTP2e
Old 06-12-2015, 12:45 PM
  #2116
Trader Rating: 33 (97%+)
Originally Posted by tc4basher
I am looking for a new center shaft that the spool and spur gear mount on. Mine is bent and I cannot find another one anywhere. Part# is 35222. If anyone has a spare one that is not bent for sale please let me know.
I will have to retire my GTP2E if I cannot find one. Please help my GTP2E live on! Haha
appears to be in stock here:
http://www.activepowersports.com/ofn...HEMaAjzW8P8HAQ
billdelong is offline
Old 06-12-2015, 01:35 PM
  #2117
Originally Posted by billdelong
Nope. Ordered one from there last nite. Got a email today saying i got refunded and its discontinued.
tc4basher is offline
Old 07-12-2015, 04:09 PM
  #2118
Questions?? Diff cups get hot?
Is it normal for a diff cup (the ones the center shafts go into) to get pretty hot after a couple blasts up and down my street?
My setup is Neu Castle 2200kv, Mamba Monster 2, 6s, geared 36/29 (3.89 FDR)
Old 07-13-2015, 09:19 AM
  #2119
Old 07-13-2015, 10:52 AM
  #2120
probably not... if your fluid is too thin, you could be cooking your diff:
Old 07-13-2015, 12:44 PM
  #2121
Im running stock diff fluid in front and stock grease in the rear. The rear diff cup gets hotter than the front but only if I get on it hard up and down my street. I have also had 4 or 5 diff pinion bearings explode!
Old 07-15-2015, 11:52 AM
  #2122
Default My solution to hot diff cups
I tried adding a 5mm shim in between the diff cups and bearing just to give the bearings some room to disipate some of the heat and it seems to have done the trick. The diff cups stay much cooler now. They still get a little warm but not nearly as hot as they were before the shims.
