Xray T3 2011
#1126
#1127
No boost- 13.5 in the 7.0-8.0 range and 10.5 in the 7.5-8.5 range
Those are just starting points.
If you don't know how to calculate your FDR then there's a section on rctech for newbies. You can find what you need to know there.
#1128
#1129
Kyosho 1000 oil is good choice,
or Xceed 1200, Kyosho 1300 !
#1130
Are you running with timing boost or no?
I would say, if running no boost, then use a FDR of around 5 for 13.5 and around 5.5-6 for 10.5.
That would be a (if using a 84 spur with an internal gearing of 1.9) 31-32 teeth pinion and a 29 teeth pinion for 10.5
#1131
Any one have any really good VTA setups for med track? Can't find much out there. Anyone using a gear diff? Just curious. Thanks
#1133
when you cut one side off the ears off the servo what else do you use to secure it
#1135
thanks whats recomended the best dougle tape for this job
#1137
#1138
hello guys nice posting.............
#1139
#1140
Mike Swauger joins RCAmerica/Xray USA
We have some Breaking News at www.rcinsider.com!
Check out the latest in 1/8 Nitro On-Road news...
Mike Swauger joins RCAmerica/Xray USA...
www.rcinsider.com
Sincerely,
Jeremy Flint
[email protected]
www.rcinsider.com
Sincerely,
Jeremy Flint
[email protected]
