Xray T3 2011
#3976
I busted the outdrive on my front spool yesterday, just wondering if there are any cheaper options than spending 35 on a new whole spool and bearing assembly when I just need the plastic outdrive. The xray part number seems to encompass the whole spool and bearings assembly with no individual part number for the outdrives
http://www.teamxray.com/teamxray/pro...0Adapters%20(2)
That thing?
#3977
CHeers
#3979
xray t3r anti roll bars???
Hi just got one just seeing what anti roll bar I should start out with on a mild grip carpet track??? Also what is the final drive ratio on the xray to figure out the gearing??? Thanks
#3980
Hello guys, recently I built a T3, everything went smooth. I decided to use a hobbywing Xerun 8.5T motor and Xerun 60A esc. My friend has the same motor and esc on another touring car with a 80 tooth spur and a 26 tooth gear and the engine gets way to hot. Our track is very big and offers a massive straight. Would like to know what gearing would you guys recommend me in order to keep the motor within safe temps.
#3981
#3983
im looking to get spec r gear diffs fr and rr what size gear do i get for fr and rr do i get the same also what size cvd do i have to use 52 or 50 thx
#3984
Can somebody please take a pic of "THE chassie modd" and post it here? And what will it do with the car?
Sorry for the bad english, hope you understand
#3985
You can use 52 shafts in the orignal xray gear diff, you cant in the spec r you have to use 50mm shafts.
I have tried both and I broke 2 spec r diffs. I am still running my xray gear diff after a full season and still going strong
#3986
Finally, a cheap battery retaining option. Obviously poplular as it is already sold out.
I will let you know how it goes as I managed to order one before stock ran out.
http://www.rc-mushroom.com/product_i...-mount-p-24221
#3987
The kit internal gearing is 1.9
#3988
#3989
Xray T3r
Thanks I will give that a try.
#3990
I found my 2011 too twitchy and I'm driving it now with the modded chassis and I have the 2011 and 2012 topdecks. Depending on the track conditions I switch the topdeck.
Here's a picture (not mine, but you get the idea)
http://www.rctech.net/forum/attachme...1-dsc09148.jpg
