Xray T3 2011
#3406
When u use xray geardiff on t2-009
U need 50 mm drive shafts?
Please Quick!
Please Quick!
#3407
#3408
anyone have a clue how long it takes until we will see a T3 2011 in a Spec R version now that the T3 2012 is coming?
#3410
Half of my car is either spec-r, cso, zeppin or some other aftermarket product already!
#3411
I think he means an 'R' version, like the T3R, with FRP instead of carbon fibre etc.
You may well find there won't be one and the T3R will still be the 'budget' version.
#3412
GEAR DIFF
Can someone tell me what a good starting point would be for gear diff oil in the front and back. The track is medium traction outdoor asphalt. Also was looking for an explanation in regards to which way to go if you need more rear traction.. example thicker or thinner oil?? thanks
#3413
#3414
can anyone tell me if a Spec R gear diff gears will work with the Xray gear diff? Are they the exact same dimensions?
#3416
The outdrives on the Spec R stick out a little bit more meaning you have to run 50mm driveshafts (or widen the rear track at the wishbones), but other than the outdrive issue you can use both.
#3419
#3420
