Like Tree2Likes
Xray T3 2011
Old 08-21-2011, 12:30 PM
  #2896
Right then I'll give it a go, to think I was actually thinking of raising the roll centres with the blocks, proves what I know!
Will I still get good direction change as it is a pretty technical track, a few chicanes in there?
Mb3195 is offline
Old 08-21-2011, 12:44 PM
  #2897
hi
is this a good chassis has someone tried it ?
Zeppin ZR-T3001 Xray T3-11 Flex Chassis 2.2mm Graphite
thank you
Corally_27 is offline
Old 08-21-2011, 04:11 PM
  #2898
Skiddins's Avatar
Originally Posted by yokemad
Thanx Fred
I was thinking its there to stop collapse @high speed tracks like you said but while I was searching some setup sheets on one of them it says post been used to stop wheel arch cracking ...
Is that right?
Thanx again...
I've known it to be used for both reasons.
Since i've started doing it I've found that the wheel arches take a lot longer to start cracking at the wheelarches etc.
Skiddins
Skiddins is offline
Old 08-21-2011, 04:32 PM
  #2899
yokemad's Avatar
Skiddins
Do you know What ;Those Wheel Arches are always a problem for me despite my hard work on Body Prep. (sanding etc.)
I'm gonna try that Extra post to see if that helps
Cheers
yokemad is offline
Old 08-21-2011, 05:00 PM
  #2900
HarryLeach's Avatar
Yep, center front body post is the single best non-handling change I've made to my car. Wheel arches last longer, and body tuck on the tires seem to happen less.
HarryLeach is offline
Old 08-21-2011, 08:08 PM
  #2901
syndr0me's Avatar
Trader Rating: 32 (100%+)
Any idea why Nexus would delete the gear diff from their site?
syndr0me is offline
Old 08-21-2011, 08:11 PM
  #2902
Trader Rating: 11 (100%+)
Maybe they are sold out of them.
light is offline
Old 08-21-2011, 08:22 PM
  #2903
syndr0me's Avatar
They don't usually remove things from the site entirely though, when they're out of stock. Its old page says "product not found."
syndr0me is offline
Old 08-21-2011, 11:20 PM
  #2904
kinga's Avatar
Trader Rating: 15 (100%+)
Just bought one from rc mushroom, they sell out pretty quick everywhere lately.
kinga is offline
Old 08-21-2011, 11:23 PM
  #2905
kinga's Avatar
Originally Posted by Mb3195
guys,
whats the best way of loosening up the car a bit when you have too much grip?
I've got a t3 '11, have recently rebuilt it, took it for a practice day yesterday on a high bite technical/mid carpet track, car felt awesome to drive, went exactly where I intended, great balance left/right front/rear, the problem is my lap times were a little down on what I would normally expect.
I think if anything I was generating too much grip and was bogging the car down, scrubbing off too much speed in the process.
I've got my setup posted here if anyone wants to cast there eyes over it:
HTML Code:
http://forum.teamxray.com/xform/index.php?act=view&ID=603&setup=t3_2011
mark
I see you are running full length wheelbase, I have found shortening the wheelbase at the back by 1 or 2mm livens the car up for technical track.
kinga is offline
Old 08-22-2011, 02:23 AM
  #2906
E-clip's Avatar
Trader Rating: 39 (100%+)
Default Shock bladders ripped ??
I have just gone to rebulid some 2nd hand shocks I brought to find that the bladders in all four shocks were ripped around the lip with only about 2mm left holding it together.
The bladders are the new 2011 low membranes.
Has anyone else had this happen to them ??
or is this some team speed secret ??
I don't see how they could be torn like this
The shock caps also had been drilled out and plugged with grub screw for rebound I guess
E-clip is offline
Old 08-22-2011, 04:08 AM
  #2907
bfong13's Avatar
Trader Rating: 18 (100%+)
My low-profile membranes have torn before, but not as bad as that. My guess is that either the shock caps were screwed on too tight or the shock shafts were pushing all the way up into the membranes.
bfong13 is offline
Old 08-22-2011, 04:48 AM
  #2908
Team EAM
Trader Rating: 79 (100%+)
They probably have a setting in OS Commerce that they forgot to click when adding it to their site. You can select "Disply out of stock" on there and it will show the product but show out of stock. If you dont select it it will just take it from the site all together. So it depends on who added it to the site if they clicked it or not. Ive seen several things on their site lately do that.
EA
EAMotorsports is offline
Old 08-22-2011, 04:58 AM
  #2909
E-clip's Avatar
The caps were on very tight when I tryed to unscrew them
E-clip is offline
Old 08-22-2011, 05:02 AM
  #2910
kinga's Avatar
Originally Posted by blade072
just got my t311 cso racing chassis.....i must say its very nice indeed....let the building begin....i also have the zeppin racing brace...but i do like what i just saw above....very nice...
Just spent all evening trying to get the zepping racing steering brace/ center steering link bridge working. It makes the steering arms rub on the front belt when turning left/right. Dont bother, spend the extra cash and get the exotek one.
I tried every conceivable orentation and when installed, the steering ball caps rub on the belt when turning the wheel left to right. Its only 2 or 3mm off, but its enough
kinga is offline
