Xray T3 2011
#2386
yes David Ehrbar has been running one , he won the B main modified ETS race at Apeldoorn
I used his set up on my T3 2010 and it was on rails , thank to David for all the set up advice and parts supply
my H final win in Pro stock is thanks to you mate
#2387
What shell do most people prefer on the T3'11 ?
#2388
I've got a pair of single hole rear uprights to try, to make rear link longer, any ideas what change in handling to expect in terms of ease of rotation, turn in, mid corner and exit steering?
#2389
#2391
They look more straight up and down to me, not at a angle, so possibly short but low. Maybe ?
Like the lock pin should be covering one of those top two locator holes.(I think?, have to check my car when i get home)
#2392
its in the rear of the car, its to get the rear not to roll as much, but its hard to say, if the lower arms are in a different position (lower to) it could be just a little less roll
#2393
#2394
Wonder what the "C" stamp on the arms mean? Carbon maybe??
#2395
Xray tests different grades of plastic all the time. I'm sure that they are trying to match the "stiffness" to the temp and track conditions. Trust me ALL the others do it as well, just because the mold is the same shape doesn't mean the plastic is the same.
#2397
An alternative to the heat shrink tubing is a product from RC TRIM, it is a vinyl wrap specifically for the xray ECS drive shafts.
p.s. another nice thing about the tubing or wraps is it also helps keeps the dirt out.
good luck
Jake D.
#2398
+ 1 on heat shrink
You can break a pin and not know it for sometime. If the shaft plunges in and out with the heat shrink on, one of the pins is broken.
Also if you have some Hudy graphite grease it seems the best lube for the ecs and cvds.
- James
- James
#2399
selling my ecs s
http://www.rctech.net/forum/r-c-item...ve-shafts.html
and sweet bag
http://www.rctech.net/forum/r-c-item...-must-see.html
and sweet bag
#2400
http://forum.teamxray.com/xform/inde...=1952&setup=t3
