lipos for a Blade mCX2
is this a good battery for the mCX2 ?
http://www.amainhobbies.com/product_...Ah-2-Blade-mCX
or is there something better? only having one battery stinks
I tried a non-Elfite lipo in mine and got burned - the connector pulled off in spite of my carefully trying to get it connected to the charger - waste of money. I've had good results from the Hyperion lipos and they are all I'll use.
http://www.allerc.com/product_info.p...oducts_id=5105
These have been tested on RC Groups and they perform as rated. They are 5C charge capable. Be careful with the biggers ones - even the slightest bit more weight and it'll unbalance the heli. Try a quality 120mah - theres a big diff in flight time and performance vs the elite batts.
The TP should be good as well.
Yeah the e-flight batts commonly drop off pretty quickly.
The common sense batts work OK.
I've used a few Desire Power lipos in various configurations/capacities and they have worked very well for me so far.
I really like the Hyperion 160's they make my MSR's nose heavy, but I just trim it out and enjoy 1-1.5 minutes more fly time compared to the stock E-flight batteries.
I have found that the Tenergy batteries really SUCK... I will stick with Hyperion for sure, I also use the 3s Hyperion's in my SR
J.T.
J.T.
I'm almost there - I'v worn out 2 MCXs and have replaced the motors in my CX-2 for the 2nd time. I've got a TR 450 clone in the late stages of building, waiting on my new radio, Futaba 7C and we'll see what this one can do...
Hyperion 3S 2200 lipos for the HK450 clone.
I learned (the hard way) anything with the tenergy name on it prob is a waste of money....
duster what did you fly in between the mini's and the 450?
is a 250 a good in between point?
or something else?
i can easily seeing myself wanting something larger that can fly outside.
the thought of building a heli seems kind of daunting to me. is it tough?
looks more challenging then a offroad buggy
or something else?
or something else?
or something else?
Building the basic airframe isn't a big deal, but getting the servos installed and setup and getting the radio setup - much more complicated than anything I've had to do with a surface rc. Getting all the servos and radio working together so the swash is setup right has been the hardest thing. I'm still messing with this stage, its critical so it simply has to be right, close won't do!
I thought I'd be OK since I had the manual, but soon found out the manual assumes you know what you're doing. Thats where the vids on helifreak have been really helpful. There is a ton of high quality help out there, the vids on each phase of building a Trex 450 have been a huge help, more so than the manual. I could have saved some time and effort if I had started with the vids.
Its not that hard if you know what you're doing - and thats the hard part, finding enough info to learn what the manual really means.
A:no one really knows and some people have somehow just stumbled onto,
or
B:they're trying to keep secret. Maybe it's a right of passage thing.
Either way, there were some things that just didn't seem to be available on the internet. And yeah, most manuals are just very rough, general guides at best.
Heli setup is indeed a mystery wrapped in a riddle inside an enigma. But once you get it figured out, it's all really very straightforward and logical, and all the bubble levels and stuff that people will tell you to use are just nonsense and a time wasting distraction. Maybe (hopefully) things have changed, but that's how it was a while back. It got to the point that I just had to sit back and forget most of the stuff I read/saw and just look at it for what it is.
Did you have to do any mods to the MCX2 to get the Turnigy 160mAh to fit?
