Speed Passion Short Course Combo 3600kv
This is the same exact combo sold on AMAIN for $139. Mine is new in package - will also include some xtras with this sale. Like, priority shipping and misc speed passion gear.
Price is $90 with free priority shipping.
http://www.amainhobbies.com/product_...r-Combo-3600kV
Speed Passion Citrix Short Course Master Sensored Brushless ESC/Motor Combo (3600kV)
[SPASC11036]
Low Price: $139.99
Click to enlarge
This item earns up to 140
Customer Rewards Points!
In Stock!
Free Shipping Eligible!
(See Details)
Wish List!
Buy Now!
This is the Speed Passion Cirtix Short Course Master Combo System. This combo includes the Citrix Cirtix Short Course Master Sensorless ESC, the Ultra Sportman V2 Short Course Master 3600kV Sensored Motor, and a ESC Programming Card. This is the perfect Short Course brushless system! The Short Course phenomenon is revitalizing electric racing across the country, and the Citrix Cirtix Short Course Master system mirrors all the best parts of Short Course racing; Inexpensive, durable, easy and FUN! The 3600kv custom Short Course brushless motor is a perfect balance of improved speed from the stock power system, but not so over the top that handling is compromised by excessive power. The legendary Speed Passion smoothness and excellent throttle feel is in full effect with this exceptional motor and ESC combo. The setup and options of the Cirtix Short Course Master ESC is as easy as it gets with one button setup and pocket programming card. No laptops, no beeps and flashes – just FUN! Upgrade your Short Course truck with the perfect balance of improved performance and smooth feel of the fun and affordable Cirtix Short Course Master system.
Programming the ESC is very easy and fast with the pocket sized programming card. To change settings, just plug the receiver wire from the ESC (trio wires with black, red and white color) into the socket of the program card (The socket is on the right corner, and marked with ), and then power up the ESC, each item’s value will be shown on the program card. the “ITEM” and “VALUE” buttons are used to select the programmable items and new values, and press the “OK” button to send the new settings into the ESC.
Features:
* Compatible with all sensored and sensorless brushless motors.
* Suitable for 1/10 and 1/12 on road and off road vehicles
* Built in ESC enhancement feature will allow updates to the latest DRRS Version 2.0 software and future new software developments. (Cirtix ESC PC-USB adapter “SPESCPB01” is sold separately). Updated software and features for the Cirtix series ESC can be found at www.speedpassion.net when available.
* New “Cirtix - Dynamic sensor technology series” feature. A state of the art new development in software will give you top efficiency and wide power band for consistent performance and highest power output!
* Proportional ABS brake function with 9 steps of brake adjustment, 9 steps of Auto drag-brake adjustment.
* New “Digital Racing Response System - DRRS” modes Version 2.0 (From Level 1 - smooth to Level 9 - aggressive). Fully upgradeable for different modes and levels of tuning.
* Multiple protection features: Low voltage cut-off protection for lithium battery / Over-heat protection / Throttle signal loss protection / Motor locked protection.
* New “Dynamic Multi Timing System - DMTS” special 8 mode adjustment system design for any brand of brushless motor to bring out top performance for both the ESC and motor.
* Easy one button programming and compatible with pocket-sized SMART ESC program unit.
* 3 running modes:
o Forward with brake “No Reverse”
o Forward with brake “Reverse after FULL Stop”
o Direct "Forward/Reverse with brake"
Specifications:
Burst Current: 90A
Resistance: 0.005ohm
Battery: 4 - 9 Cell NiHM/NiCd, 2 Cell LiPo, 2 - 3 Cell LiFe*
BEC Output: 6.0V/BEC 2A
ESC Type: Sensored
Motor Type: Sensorless or Sensored brushless motor
Dimension (LxWxH): 32x28x18mm without cooling fan
Motor Limit: 9.5T Max
USB Software Upgradeable: Yes
ESC Fan: 25mm
[SPASC11036]
Low Price: $139.99
Click to enlarge
In Stock!
(See Details)
Wish List!
Buy Now!
Features:
* 3 running modes:
Specifications:
Burst Current: 90A
ESC Type: Sensored
ESC Fan: 25mm
Trade
What other RCs do you run? Would you want to do part trade and part cash. I have a Venom 20c 3s 4000mAh lipo, EzRun 60A esc, and a 1/8 Brushless EzRun motor 3665 2300kv motor, two TRX 2056 WP servos, Losi/spectrum 2.4 RX/TX, HobbyKing Quik 100A continous 540A peak 2~4s lipo capability ESC, New set (4) 2.2 Axial Rock Lizard Tires pulled from AX10 kit(never mounted), new Alum set of rod ends, etc
