Like Tree4Likes
Tamiya TRF417
Old 02-01-2014, 12:56 PM
  #6316
Originally Posted by JoeyE
I have them on mine. 418 shock towers, 418 suspension, 418 sway bars, YOKOMO BD7 center gearing.
All (4) screws line up? What diff oil do you have in the rear? I hope Tamiya USA allows the lowered towers to be legal on the 417.
Juan Aveytia is offline
Old 02-01-2014, 03:23 PM
  #6317
JoeyE's Avatar
Trader Rating: 45 (100%+)
All 4 screws line up. I use Associated Black grease in my diff gear.
JoeyE is offline
Old 02-02-2014, 06:54 PM
  #6318
Trader Rating: 54 (100%+)
I've been checking petit rc for 17.5 blinky med grip carpet set ups and seen different shock oil brands used, trying to find a good starting in losi wt? I've seen and have all the conversion sheets for brands and cst to wt but some have muchmore listed also ....some charts are showing mm 450 equal to 50wt seems little heavy
rkhess is offline
Old 02-02-2014, 06:56 PM
  #6319
golgi's Avatar
Trader Rating: 15 (100%+)
What are the handling traits between stock undrilled shocks and those with caps drilled for aeration on this car? I bought mine used have the drilled shocks so I don't know if there is any benefit to switching to undrilled caps.
golgi is offline
Old 02-03-2014, 01:00 AM
  #6320
C van der Hagen's Avatar
You are missing the SRP motor mount
C van der Hagen is offline
Old 02-03-2014, 06:26 AM
  #6321
JoeyE's Avatar
I used the 417 motor mount. Works fine with the YOKOMO gearing. What is SRP?
JoeyE is offline
Old 02-03-2014, 06:41 AM
  #6322
Its this
http://www.thercracer.com/2013/10/se...rsion-set.html
Work's a treat on my 417
Qatmix is offline
Old 02-03-2014, 03:32 PM
  #6323
clint's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Qatmix
I went the Smokem route.. same blue as TRF, not Yokomo Blue..
clint is online now
Old 02-06-2014, 10:55 PM
  #6324
Burlap's Avatar
Has anyone got a good VTA (Vintage Touring) setup for the 417?
I have a 417 v5 with soft Raceberry chassis. The track I race on is low grip tight asphalt. I'm guessing a good start would be a low grip chassis setup from somewhere like Petit RC, but are there any other changes I should add to that?
Burlap is offline
Old 02-08-2014, 06:28 AM
  #6325
Does anybody know the size of the narrower inside bearing when using the front double Cardan joint?
Atechbh is offline
Old 02-08-2014, 07:25 AM
  #6326
subaru73's Avatar
Trader Rating: 42 (100%+)
Default 417
1050 bearing 3 mm wide tamiya #42220
subaru73 is offline
Old 02-08-2014, 08:29 AM
  #6327
Johnn27's Avatar
Trader Rating: 89 (100%+)
Default cooling fan
Hey JoeyE where can I get that cooling fan ???
Johnn27 is offline
Old 02-08-2014, 09:46 AM
  #6328
JoeyE's Avatar
I bought it tqrcracing.com.
http://www.tqrcracing.com/shop/produ....asp?p_id=5980
JoeyE is offline
Old 02-09-2014, 08:09 PM
  #6329
g12314's Avatar
If anyone has a 417 V5 chassis they would like to part with, please PM me. While testing for the upcoming TCS races managed to blow out the rear toe block screw . I guess worst case, I get a 418 if a V5 chassis cannot be found .
Thanks,
Jimmy
g12314 is offline
Old 02-09-2014, 08:16 PM
  #6330
JoeyE's Avatar
Thanks,
Jimmy
I have a used V5 chassis. The only thing is that I have to look for it(I know I have it). I would say the condition is 8/10. When do you need it by?
JoeyE is offline
