Tamiya TRF417
#6031
Does anyone know if I will be able to run this body on a 417 with standard shocks and towers? It says it works for a 415 so I'm hoping it will work <crossing fingers>.
https://www.tqrcracing.com/shop/prod....asp?p_id=5953
#6033
Get rid of the tamiya springs too, yellow and red are way too soft
Also are you running no bars?
#6034
Get rid of the front kick up, run the blocks flat or with 0.5mm anti dive. Using hole 2 on the front arm also increases mid corner steering, so you may just have way too much front bite with the smokem conversion.
I was running blues front and yellow rears, but someone suggested me to go softer that night so I did in hopes to solve the issue. (Which I didn't wash out as much but it could be that that traction came up a little bit too)
I'm not running sway bars at the moment.
Some also suggested me to try out david jun set up from tamiya as a start up, do you agree?
#6035
Wow mugen replica on a BMW... lol...
that body is sweet prolly with better wheels though
#6036
Tamiya springs dont work well on ashpault and running no sway bars would have caused problems. I cant remember if I added the rear diff oil in the setup but run 2000.
Important to note: front shock mounting position in the arm to hole 1 (you need to flip the arm over)
Oh and upper link position front and rear in hole 1 (middle hole)
#6037
all this setup talk... are there any good smokem 417v7 setups floating around?
#6038
#6039
#6042
#6043
I would try Craig's AOC setup - http://www.petitrc.com/reglages/tami...ourne20130707/
It's for a Raceberry but it won't be that far away as a starting point.
#6045
