Like Tree4Likes
Tamiya TRF417
Old 09-11-2013, 12:40 PM
  #5941
Originally Posted by rkhess
Good have him start working on a TB04pro chassis conversion!
That would be great, as it doesnt seem like an Evo6 is on the cards yet
Qatmix is offline
Old 09-11-2013, 02:49 PM
  #5942
Hebiki's Avatar
Trader Rating: 26 (100%+)
yes please!
Hebiki is offline
Old 09-12-2013, 01:20 AM
  #5943
Originally Posted by CraigM
Just a longer rear wheelbase because the motor is further back with the Smokem V7 compared to the RB
Kentech mod has no screws in the motor mount so the flex point is more or less in the middle of the car
Smokem conversion has only 1 top deck screw in the motor mount at the front which moves the flex point forward, but also lets the top deck to flex freely above and behind the layshaft like yokomo/raceberry
Sepes conversion (like 417) can't do that configuration easily, either it will be just like kentechs mod with the flex completely in the center or it will be like a standard 417 with the rear end very stiff
The best of all worlds is the 418, it has a captured layshaft so you can run it like the yoke/RB but also has screw holes over the layshaft to stiffen up the rear end if the track demands that
For the Smokem - there are actually top deck screw holes on the motor/layshift mount so it is possible to stiffen up the rear if required.
One advantage of Smokem is that, if you have V5 bulkheads, then you don't need to add any shims under the topdeck. If you are running 417/417x bulkheads, then you need 1mm under but have the option to not add the shims and level the motor mount + screw to stiffen up.
The other advantage is that the original 417V5 bottom deck/belts can be used with the smokem.
Overall, I feel that the Smokem provides a more consistent drive/ more rear grip than stock with the same setting, someone us have therefore, changed our setup to give more steering.
iwkyb is offline
Old 09-12-2013, 03:24 AM
  #5944
CraigM's Avatar
Trader Rating: 34 (100%+)
I didn't realise that, the pre-prod version I have is a little different to the production one
CraigM is offline
Old 09-12-2013, 07:00 AM
  #5945
C van der Hagen's Avatar
The big advantage of the Sepes Conversion set is that all parts are could separately being used with the TRF417
One possible configuration is the use of the original motormount with center post and lifted (free from the centershaft holder) top deck.
Another configuration is the use of only the sepes motormount with the original TRF417 topdeck.
The lifted topdeck is tested with 1.5mm spacers under the bulkheads in combination with the original lower deck which gives the best flex properties.
Please note that the Sepesmotormount has a new design middle layshaft holder. Different from the original ‘open’ part the ‘closed’ designed of the bulkhead captures the layshaft bearing to allow to lift the upper deck in order to further adjust chassis flex and therefore the characteristic of the car.
C van der Hagen is offline
Old 09-12-2013, 09:52 AM
  #5946
Can you race stock (17.5 blinky) with the Sepes motor mount and no screws in the top deck other than the front and rear bulkheads?
Qatmix is offline
Old 09-12-2013, 12:34 PM
  #5947
Yes, with a chamfered front plate of the motor (like speedpassion) it should be possible. Which spur/pinion do you use?
Old 09-13-2013, 06:28 AM
  #5948
Vincent also corrected me on 1 point.
If using TRF417x Bulk heads and want to use the two top deck holes, then the centre post of the smokem conversion cannot be used since it will sit too tall.
The other option is obviously to shim up the top deck + motor mount
iwkyb is offline
Old 09-13-2013, 09:47 AM
  #5949
I just picked up a 417 with front and rear gear diffs and will be racing 17.5 blinky this Sunday on a 80x40 indoor carpet track. Can somebody please give me a starting point on gearing and fdr . Thanks in advance !
mikpiz is offline
Old 09-13-2013, 11:58 AM
  #5950
For my 417 I used a 100t spur and 49t pinion for 17.5 blinky with my ORCA at about 3/4 advance timing and it was smooth and fast without the motor getting very hot.
Also I used a gear diff with 500k oil in the front sometimes if I found any corners too tight
Qatmix is offline
Old 09-13-2013, 01:03 PM
  #5951
Typeone's Avatar
Trader Rating: 50 (100%+)
If I run .5mm wheel spacers in front and 1mm in rear will that give me better turn in?
Typeone is offline
Old 09-14-2013, 12:55 AM
  #5952
vivo quevas's Avatar
Trader Rating: 19 (100%+)
I ran the Smokem V7 conversion last night the biggest thing I noticed the car was real darty and hard to drive early in a run but it wouldn't over rotate as soon as the tire sauce wore off the car was great next time no sauce or just sauce the inside of the front tires. I was really happy how the car ran from 2 min into the race till the end it was fast qualified 2nd and was real happy with my car.
vivo quevas is offline
Old 09-14-2013, 05:28 PM
  #5953
CraigM's Avatar
A little, it's more noticeable mid corner IMO
CraigM is offline
Old 09-15-2013, 09:20 AM
  #5954
ATLASCOPCO's Avatar
Has anyone put a gear ratio chart together for the raceberry conversion yet??
I do know that you can use your calculator but its better for me to look at a chart
Cheers
ATLASCOPCO is offline
Old 09-15-2013, 10:20 AM
  #5955
Cheers
Make your own at http://www.tqrcracing.com/rc_tools/gearing.asp
1.85 is the internal ratio.
dizope is offline
