Tamiya TRF417
#4381
Hey guys, it's no harder than to put another servo mount with screw in the rearward center holes as well if you want to have a support there. This way, using the front screw in the servo mount and this rearward screw, you can even adjust the battery position sideways. Or just put a some weight there with doublesided tape, as someone already suggested. Those are 2 solutions if you do not want to buy any special part from the old car.
The battery support with servo mounts works very well, I have been using it for 2 years without one single problem. It is a very neat and simple solution that lets you adjust according to battery size (remember to leave a small gap to not tweak the car) and battery position.
Don't make a problem out of a non-problem. At least not until you have tested it.
#4383
This is a general setup question for my 416XL car.
My car is not rotating very fast in the slow tight section on the track I race at. I have finally got my car to feel very stable on the high bite carpet track I race at.
My question is, should I focus on the rear of the car or front of the car setup to get the car to rotate better in the slow section of the track?
I feel the car does not respond to small setup changes at all. Is this common for this car?
#4384
Mugen i would personally focus on letting the back of the car slide a little to help it rotate
#4385
If i put the new top deck onto a trf417x am i right in thinking that i will need to drill 2 holes in it so it screws into the layshaft mount as i wont have the layshaft mounts with the extra pegs on the bottom
#4386
Dose anyone know where i could purchace Tamiya clothing please
Thx
Thx
#4388
Is there a chart so I know which combinations of suspension mounts will tell me how much toe in I have? So that I can adjust it
#4389
#4390
#4391
#4393
#4394
Damper Stay
Hi
For the tcxx they make the front and rear damper lower , to change the packing of the damper , do tamiya also do that ??
#4395
At Italian Charity Race Viktor took the overall win with his new Tamiya 417v5, well done!!!!
