Tamiya TRF417
#3646
#3647
Are you guys running locktite on all the metal to metal threads?
#3649
I wonder if the new car will come with 0.5mm shims for under all the bulkheads?
Can any trainspotters out there figure out what damper cylinders they used at the worlds? I thought they were the TRF buggy ones but the buggy HL dampers won't take the blue lower cap - their lower shock cap is an insert style.
http://www.rcmart.com/tamiya-42132-c...h=595_744_1011
and good to see you spotted the 0.5mm shims under the motor bulkheads too... how about the top deck minus the front motor mount screws and holes?
#3650
I think its .5 under all the bulkheads not just the motormount, hence the lower (3mm) inner camberlinks.
#3651
Definitely not
Yep noticed that too. New shocks, interesting. As the guy above said you can see the 0.5mm spacers under the other bulkheads too
Come on Craig... they are buggy tops with custom (i.e. proto) cyclinders... had a chat with a few guys there after I saw the pics...
#3652
What does the raising of the bulkheads do for the handling of the car?
#3653
I don't see spacer under the other bulkheads, but I wonder if its a new motor mount?
On the battery side it looks abit short without the spacer under it.
Or maybe its just me.
I think spacer under bulkhead is lowing the roll center.
#3654
The battery holder from the 417 are carbon pieces and are lighter.
14004079 - Narrow
14004080 - Wide
14004081 - Center
All three can be found here. That being said, most do not run the side pieces.
14004079 - Narrow
14004080 - Wide
14004081 - Center
#3658
Does anyone know why tamiya discontinued the trf 417x?
I was just about to buy one.
