Tamiya TRF417
#332
http://rcmarket.com.hk/product_info....oducts_id=9797
#333
umm dude i think there is one i might be wrong
#334
Anyone knows any other brands of spur gears (48 and 64 pitch) that fit the new TRF417? I've tried the Kawadas and they don't fit.
#335
Xenon new spur gear !
TRF417 later some hours arrive !
#336
Anyone tried that gear diff?
#339
Spoken to other people who've also run it, and since they've fitted the X-rings, no problems with leaking at all.
Will admit to not having even looked at the NT1 diff, may have to do that.
Syndr0me - I'd suggest if you are having problems with it leaking then it may be worth taking it apart to make sure it's built correctly.
#341
#342
what sizes pignion are most commenly used ?
I would like to end up with ratio between 4.5, 5.5, 6.5, 7
Just need to know what size pinion to buy ...
gear ratio = (spur teeth/pinion teeth)x 2.055 for the TRF416
is it (2.055)the same for TRF 417 ?
#343
Using a 19T center pulley, the secondary gear ratio reduction becomes 1.94, which is very close to the ideal rate for brushless motors
#344
Today some TRF417 Spare & Option parts arrived !
#345
