Tamiya TRF417
#2671
Just building my new 417X, and I've found that I can't seem to use a Tamiya v2 gear diff in the front when using the standard 1-piece 1C suspension mount in the front-rear position behind the front bulkheads, as the pully touches the mount. With the spool fitted, and 3.5mm of shims under the 1C mount (as per manual), there is a very small gap between them. If I try 4mm under the 1C mount, then the pulley touches.
I ran the v2 gear diff in the front of my 417, but I always used 1C split-mounts behind the front bulkheads. I wanted to try the 1-piece mount to start with, but it looks like I can only use the split-mounts with a front gear diff. Has anyone else come across this issue?
#2672
HiH
Ed
#2673
TRF Dampers
Hey does anyone know if there is a right or wrong way to assemble the Tamiya Racing Factory Dampers?
In the 417 Manual it shows: Spacer/ O-ring/ Large Spacer
...and in the TRF Damper package it shows: O-ring/ Spacer/ Large Spacer
Just curious, I bought a set for my old TC3 because they're so nice.
I couldn't find anything on this incase I get drilled for not looking
thanks,
-Brian
thanks,
-Brian
#2674
thanks,
-Brian
thanks,
-Brian
#2677
HiH
Ed
#2678
IIRC the manual says spacer oring spacer, I know the old black shocks come with a manual which says oring spacer spacer - Ed is pretty old school so he's probably still building his shocks the 414 way
I run kyosho now and the velvet shocks use 2 xrings and then the bottom spacer. They are the best shocks I've ever run and only need to be rebuilt when you want to change oil viscosity, so it might be worth trying on the tammy
#2679
TRF Dampers...
Thanks guy so much! Will look into these o-rings and shims when it's time for a rebuild
#2680
http://www.youtube.com/watch?v=sliCxsIZ3v4
(2:40 - O-ring/spacer/spacer )
#2684
too sticky on the shaft.
Are you sure you are building shocks?
Are you watching the Jilles video or another video
