T.O.P Racing's Rebel 1/12th scale >
Like Tree12Likes
Old 11-24-2011, 07:12 AM
  #766
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Originally Posted by Delawareguy
I drove my Rebel for the first time last night in practice. So far I really like it. I still need to work on set up but it seems to handle well as it is. Plus is seems really durable and since I drive like a gorilla that's a good thing. My only concern is that the motor appears to move out of position pretty easily. Is there something I can do to make sure it stays in place... other than not crash?
I'd recommend getting some lundsford fatboy motor screws so you can really crank on them.
http://www.amainhobbies.com/product_...Motor-Screws-2
Ron Goetter is offline
Old 11-27-2011, 11:23 AM
  #767
Infinite 12th's Avatar
Hi, with the KO servo 951 while using the angled holder what side does it mount on?
p.s. I know the Fut9650 sits on left
Also where does the JR?
Infinite 12th is offline
Old 11-27-2011, 01:00 PM
  #768
odpurple's Avatar
KO left
JR right
odpurple is offline
Old 11-28-2011, 09:52 AM
  #769
Default tyre size
Hi
What size do you run your tyres on carpet , with a ride height of 3mm. I tried with 44mm rear and 42mm front , have CA glued the front tyres , but still the car flips. I use Capricorn 30 rear and 35 front. I think it only is the size that are the problem , as when the tyres get smaller the problem goes away
johnsen-dk is offline
Old 11-28-2011, 09:56 AM
  #770
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Originally Posted by johnsen-dk
Hi
Even for club racing I run 42 mm rears 41 fronts glued.
You may be running too much camber too. I usually run -.5 or -1 never any more
L.Fairtrace is offline
Old 12-03-2011, 06:58 PM
  #771
Trader Rating: 11 (100%+)
Raced my Rebel for the first time today. I love this car. The only problem I have is that I bent an axle. I upgraded to the threaded axles and then hit the wall hard. Does anyone know if there is a titanium axle available for this car? Maybe from Lunsford?
Delawareguy is offline
Old 12-03-2011, 07:16 PM
  #772
ByteStream's Avatar
I think the threaded axles are a bit soft ...
These might work for you.
http://www.lunsfordracing.com/mm5/me...gory_Code=AXEL
ByteStream is offline
Old 12-03-2011, 07:25 PM
  #773
Thanks. Has anyone tried these? My only concern is that the threaded axles from Top fit very tight. I wonder if these will fit correctly.
Old 12-03-2011, 07:34 PM
  #774
I had the associated type that these are based off and they fit snug but the TOP fit way tight
Old 12-04-2011, 06:17 PM
  #775
I use the Lungsford axles in my Rebel. They work really good. Also use the Turnbuckles.
SRW141 is offline
Old 12-04-2011, 06:23 PM
  #776
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
lunsford axles are the gold standard for 1/12th scale. folks have been using them for years...
hanulec is offline
Old 12-05-2011, 01:38 AM
  #777
Robert_K's Avatar
Is there already any news about an inline conversion for the Rebel12?
Regards Robert
Robert_K is offline
Old 12-05-2011, 04:28 AM
  #778
hanulec's Avatar
Regards Robert
I haven't heard any. Many inline designed cars are being run in the more traditional way.
After seeing the current 1/12 WC have to move over to let Larry pass in qualifiers at IIzc in 13.5 boosted I would say it isn't necessary.
hanulec is offline
Old 12-05-2011, 11:27 AM
  #779
lol...The WC has regular battery config as well
Old 12-05-2011, 12:09 PM
  #780
Regards Robert
I saw OD having one a couple months back I think he custom made for himself
I would rather have updated V2 steering blocks with titanium axles first though
