.12 engine break in...
I just put a new sleeve and piston in my motor. It's only and associated .12, nothing fancy. Any break in tips?
I did lube everything when I put it back together so it's not dry or anything.
Thanks!
Thanks!
I'm sure you already started your break-in, if you're impatient like I am, but here's what I used on my last 2 engines.
http://www.affordablenitrotech.com/f...t=ST&f=6&t=31&
Break in tips:
Be patient
let the engine cool between tanks
Put a few drops of high quality after-run oil before starting it for the first time
Do a few tanks of idle and few more with slow driving (number varies with engines, be on the safer side by doing more )
After break in, take glow plug out and put around 8 drops of after run oil in, then give it a few tugs or if ur using a starter box give it a spin.
hope this helps
Be patient
hope this helps
