rear suspension arms binding? >
Old 09-03-2010, 08:29 AM
lewis666's Avatar
Default rear suspension arms binding?
hi there,
i keep having this trouble with my back suspension arms binding on my losi 8ight 1.5 and not moving freely an dropping down when the shocks aren't attached.
i know it is caused by the hinge pin and suspension arm but it is ok once i clean it out but when i come to cleaning my car from a meeting they bind?
is there anything i can do to prevent this?
many thanks
lewis
lewis666 is offline
Old 09-03-2010, 08:36 AM
FLHX1550's Avatar
Trader Rating: 11 (100%+)
Well if the arms have just a little bit of wear, they can let dirt in and bind also. If you can squeeze some small o-rings in around the pins where they meet the arms it may help.
Might be easier to start with fresh arms and mounts though.
FLHX1550 is offline
Old 09-03-2010, 08:57 AM
you will probely need new arms if i was u i would
thomasgoalie2 is offline
Old 09-03-2010, 09:06 AM
Lille-bror's Avatar
Hi.
I've had the same problem on my buggy. In my case the metal suspension pins rusted a little. I removed the rust and put on a little bit of oil on the before refitting and I've no binding anymore.
Lille-bror is offline
Old 09-03-2010, 09:26 AM
Stubbs's Avatar
Trader Rating: 58 (100%+)
Generally after every race weekend, I'll pull all of my suspension arms off, run a reamer through the holes in the arms, and buff my hinge pins with a Scotch-Brite pad. I've found that it's just a small coating of grime that causes my arms to bind a little. Doing this as part of my post-race cleaning routine keeps them moving smoothly.
I've also used a little dry graphite lube with good results. Check your local locksmith shop if you have trouble finding it elsewhere.
Stubbs is offline
Old 09-03-2010, 10:18 AM
Tony Newland's Avatar
Trader Rating: 53 (100%+)
get a bag of pipe cleaners and a can of pledge it'll be a huge investment at about $5 and better than anything on the market..... keeps everything moving freely in the most dusty conditions all day
Tony Newland is offline
Old 09-03-2010, 10:56 AM
token's Avatar
another case could be the outer hinge pins are bent, or the hinge pin holder could be bent.I have never had a problem with arms that was not one of these problems.
token is offline
Old 09-03-2010, 11:08 AM
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
+1^
dirt is not going to keep your arms from falling without a shock attached, sounds like you have bent hingepins.
Trevor Williams is offline
Old 09-03-2010, 11:16 AM
great idea man!!!
Old 09-03-2010, 11:40 AM
lewis666's Avatar
hi,
thanks for the replies.
i will have a look into bent hingepins but it has been happening for a few weeks. i give my car a good going over before each meeting. so i clean my car and check suspension movement, anything bent or broken.
and when i go to clean my car after a meeting the rear suspension arms are binding where as before the meeting they where moving fine.
could it be a mixture of dirt and oil from the exhaust because it only seems to be the suspension arm behind the engine and exhaust, i think it is the left rear suspension arm?
if the hingepins aren't bent then i will try that oring idea because i have some old losi shock orings.
many thanks
lewis
lewis666 is offline
Old 09-03-2010, 07:44 PM
Integra's Avatar
O ring's or the little foams donuts don't do anything if you ask me, been there done that and it Didn't help. I feel some tracks dirt makeup is just more prone to making thing's bind up and squeak over a day/weekend of racing.
Integra is offline
Old 09-03-2010, 07:52 PM
Trader Rating: 21 (100%+)
I'd rebuild the shocks and in the process completely clean ever thing and check if any of the shafts are bent even slightly. sometimes you can't tell just by looking at them I normally roll them on a table and you will know right away if they are bent. after that refill the shocks and check if they bind at all before installing them.
TopGearRC is offline
Old 09-03-2010, 11:59 PM
lewis666's Avatar
that is my problem. dirt gets in between the suspension arm and the hinge pin causing it to bind. i don't think it is a bent hinge pin because once i have cleaned the hingepin and the hole in the suspension arm in works fine.
i will try some new rear suspension arms and see how i get on
many thanks
lewis
lewis666 is offline
Old 09-04-2010, 06:36 AM
Trader Rating: 36 (100%+)
Another thing to look at, when you secure arm holders/diff case together, just screw tight enough to close the diff case. You want to have a tiny, tiny bit of front to back play between the arm and the holders. If you screw them together too tightly, they will cause the arms to bind.
NitroOB4You is offline
Old 09-04-2010, 08:12 AM
lewis666's Avatar
hi there,
i will try that but there is a washer between the suspension arm and the rear hinge pin brace, should i remove the washer and see if that helps?
many thanks
lewis
lewis666 is offline
