TAMIYA M-06 Thread
#586
Hi,
I´m also not running MWB, but LWB.
But maybe I can give some input, as I´m also sorting out problems with spec tires. I made the same experience: on some special carpets, the m-Grips stick better than the S-ones. On tarmac the S-grips can´t be beaten, and forget the m-grip in the rain. (like ice)
I always use the hard foam inserts f/r and try in the meantime to use te same tire front/rear, to get more steering and to keep my stuff simple.
On the setups, I went from kit to very soft on a TEC race, now getting back to the harder side on our outdoor track. Currently running on S-Grips all around.
At the weekend I made good experience to reduce travel and droop in the rear, which stabilized the car a lot.
I run the Carson Cup machine with 3000 Nimh, Lipo just for training.
Well, for sure my setup is not 100% perfect at the moment, but maybe you can get some input from it. As I noticed this evening, it´also works in the rain, which is always a good sign to me.
I was able to really push it to the limit, and on some 180° curves to throw it around by the brake, to reduce curve radius...
But you´re right, with a little more power than 540, it´s way more difficult to setup the RWD. So I appreciate this thread and the enthusiasts here a lot, let´s sort out some good setups together!
BR from Germany,
Matthias
BR from Germany,
Matthias
i hope help....nice try....wait your field report
#587
Hi again,
I feel it the same way, as you describe it.
With the more weak setup I used initially for a very low grip carpet, I gained very quick entry cornering and fast response through some chicanes.
But it was also a rather small, technical circuit.
Running outdoors again, it was just too responsive with higher speeds, and gave an unsave feel.
To test your tip: I´m not quite sure if I get you right:
You recommend to reduce bump travel by putting the o-rings outside the shock on the piston rod? (like in the manual for using trf on the rear with kit piston rod)
Or do you mean limit travel by o-ring under the piston rod? That´s why I noted the shock length end to end in my setup sheet.
But one little detail I forgot: I noticed to have 0,7mm shim under the inner ball pin. (lower fr roll centre)
I also got yesterday my stabilizer set finally, tried already hard for the front and soft in rear, but gave me again a little understeer in corner entry. (not surprising). So will try soft/soft next.
Another thought I gained yesterday, to try more negative camber in rear for corner exit. Looking at my tires, they show wear down to the outside tire, maybe I get also some quicker corner exiting by this...
For sure I will try out your tipps afterwards and give you a feedback!
#588
[QUOTE=ruebiracer;9035681]Hi again,
You recommend to reduce bump travel by putting the o-rings outside the shock on the piston rod? (like in the manual for using trf on the rear with kit piston rod)Put the black rubber oring inside your shock , under shock piston rod, in this case you have to make sure your tire grip enough ..if so you can feel more quicker this we call droop or shock travel seting
But one little detail I forgot: I noticed to have 0,7mm shim under the inner ball pin. (lower fr roll centre) shim a little bit different effect...but this is fine tuning
if you felt the tire absolutely grip, you can put stabilizer to fine tuning, but oring under shock piston rod give more effect than stabiliser,,,,ussually i "ll use stabiliser when the tire felt so grip....but i am not believe TAMIYA S grip and M grip tire .....we are using stabiliser on asphalt circuit with slick A tamiya tyre...it's depending your country temperature.
I am using stabilser M05 on carpet track without oring under piston rod....tire f/r M grip....inner front :hard rear : medium.....definetely great traction on FWD
if you get more comfortable setup using M and S tire on the carpet , you can share with me...i am realy appreciate get more input from many racer
Nice share with you mathias
#590
#591
HPI Bodies for M06
Has anyone used the HPI bodies listed here: http://www.hpiracing.com/hpibodies/mini/
If yes, post some pictures of your m06 with HPI body. By the way, Tamiyablog posted the 1st gen Mazda RX7 body will be in the m06 kit.
#592
Here again after some internet problems.
Mbahdukun, nice share with you also for me!
I also noticed the droop being the most important factor at this chassis.
I will try next the second oring under the front piston.
You´re right, stabilizer is more fine tuning on it.
Had some problem with strange gear noises, hope to have it sorted now and will try next setting changes on the weekend.
I´ll give feedback here for sure.
Best regards,
Matthias
Best regards,
Matthias
#593
I have an ABC Hobby Goose rear wheel drive car which is very similar the Tamiya M-06. I bought the S Grip 60D radials for it, but I need to get the inserts. Should I use the #50686 inner sponge for the rear tires and the #53255 hard inner sponge for the front tires. Racing the car on asphalt.
Seems to me you should put the hard insert up front to make the front end less twitchy.
Any suggestions? Please help.
Thank you.
Thank you.
#594
Upon further consideration, I think I'm going to get the #53255 hard inserts for all 4 tires.
#595
Thank you, Sydewynder
I figured that the #50686 inserts might be too soft; so I decided to go with the #53255 hard inserts to give the tire better support which should help with traction.
#597
Had a test run yesterday with the reduced front droop (second oring under piston):
I felt a useful advance in turn in, even off power, really nice. Car still stable and easy to drive (for RWD). Overall the car feels a bit more firm, on uneven surface slightly hoppy now. Ground clearance still o.k. for the street.
Guess I have to get back to the track soon...
BR,
Matthias
BR,
Matthias
#598
Subscribed.
#600
new to mini
does mini body that fit m05 fit m06?
will regular 2 cell battery like this one fit m06?
