TAMIYA M-06 Thread >
TAMIYA M-06 Thread
Like Tree120Likes
TAMIYA M-06 Thread
Old 01-03-2011, 06:29 AM
  #241
redzone's Avatar
thanks for answering my question tony gray!
i can confirm the ultra rare Carson Opel Kadett C coupe bodyshell fits the M06L
redzone is offline
Old 01-03-2011, 05:56 PM
  #242
Curiosity has driven me to try fitting this body (Tamiya Datsun 280Zx from kit #92213) onto the M06 and guess what it fits like a champ! I'll try the Abarth 1000TCR next few days and will keep you guys posted!
Please post some of your M06's bodies
Attached Thumbnails TAMIYA M-06 Thread-img_6614.jpg   TAMIYA M-06 Thread-img_6615.jpg
seasons29 is offline
Old 01-03-2011, 06:56 PM
  #243
Timbulb's Avatar
As stated previously, the Abarth wont fit due to the motor hanging out the back. I use the Alfa Romeo and the Datsun 510.
Timbulb is offline
Old 01-04-2011, 01:57 AM
  #244
Originally Posted by t4m1y4niac
oopppsss i already install front-rear aluminum knuckle...
thank you for the tips...
You can also use those hollow carbon gear shafts (53390)for a M03, the're weight is only 1gr instead of 9gr. It's not much but it's a start
In the manual at step 3 you can see that D2&D12 is attached between the 2 motor plates and they can be removed, it provides some extra weight saving.
And it gives you the opportunity to install a fan on a motor heatsink to cool the motor
What i also do in many casses is that i use shorter screws then mentioned in the manual, this saves also some extra weight
For example in the suspension arms i use 8mm screws instead of 10mm and this can be done with many screws
addicted2blue is offline
Old 01-04-2011, 03:19 AM
  #245
PizzaDude's Avatar
Why then not just ditch the screws and glue the arms together?
PizzaDude is offline
Old 01-04-2011, 04:09 AM
  #246
Cause i think that they will break when you have a serious crash and for racing isn't that the best option (I think)
Old 01-04-2011, 05:54 AM
  #247
t4m1y4niac's Avatar
i already did all the tips you gave to me (thank you so much)
and not bad...still trying to make about 1300 gram with ready to run condition.
gluing arm is to extreme for me, i will not do that.
aluminum motor mount..is it a "have to" item?
t4m1y4niac is offline
Old 01-04-2011, 08:15 AM
  #248
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
I have the glued the arm together and not a problem for me ....
If you did break ,you are going to get two set parts of arm any ways.
btw I never known anyones ever break an arm off, those part are very forgiving..
OVA is offline
Old 01-04-2011, 09:38 AM
  #249
I don't think it's a must have item, but if i have the choice i always used an alu motor plate.
And always use the motor spacer inbetween, cause if you don't use that and the motor is getting to hot it could melt down the plastic.
I have all the alu parts installed and the weight should be arround 1300 a 1320gr (with a intellect lipo stickbatterij that doesn't have wires but tubes, weight only 209gr and it's 3800mh with 50C)
Old 01-04-2011, 09:39 AM
  #250
I have glued the arms together too, and never broke one yet over the three years racing mini. It is one of the must have mods that Jpn racers use.
redbones is offline
Old 01-04-2011, 04:10 PM
  #251
frankthetank's Avatar
Trader Rating: 41 (100%+)
Any thoughts as to handling on with the short wheelbase with the M06 for those that have tried it. I have mine built and am going to test the SWB, I used the MWB, since I already had an old Miata body from my 04...Tamiya Miata fits well BTW. Just looking for some insight from folks who may have already done it.
frankthetank is offline
Old 01-04-2011, 05:24 PM
  #252
this guy found a setup that works quite well. there is a set up sheet at the bottom of the page. The page is all in Jpn though.
http://machine-rc.dreamlog.jp/archiv...3015.html#more
this is for the MWB, but all he did was use the 2deg rear hub for the SWB, and it worked well also.
inpuressa is offline
Old 01-05-2011, 03:55 AM
  #253
t4m1y4niac's Avatar
last night i'm start thinking about gluing arm...so..what kind of glue should i use?is kind of shoe goo strong enough to hold those arm??i have Amazing Goop from Ace HardWare.
@a2b : my battery is very big i use Team Orion 5400mah 45C...and this give me problem about weight saving
Old 01-05-2011, 10:57 AM
  #254
BumFacedGoat's Avatar
i dont know wht its like where you race but i know a guy at my local track got dsq for gluing his arms together instead of screwing them. they said it wasnt built as per the instructions.
BumFacedGoat is offline
  #255
R/C Tech Elite Member
monkeyracing's Avatar
Crazy glue (CA glue, cyano-acrylate) will do the trick. A drop or two on the mating surfaces, screw it together, wait, take the screw out. Voila!
monkeyracing is offline
