Mud Guards? Yes or No
Those black plastic guards that run along side of your chassis are called stone guards, not mud guards. The primary purpose is to help prevent rocks from getting flung off your tires and onto your chassis, which will cause major problems if it finds its way to your gear mesh or linkage. naturally they also help keep mud off your chassis also.
#20
well you can do if you want but it dont make any different it will still get muddy
#21
now that's pretty funny drag....
But instead of picking the dirt out of the rear arm webbing you can just give the guard a whack with a driver and the Whole Clump falls off.....Muddy is Muddy yes But the Guards keep thing's cleaner NO question's asked.
#22
My vote is yes depending on the conditions. Racing in Florida especially thru the rainy season track conditions are going to warrant them. I make my own and even run them on my chassis gaurds as well. I have seen some cut up old buggy bodies and run them inside truck bodies to help. You can take on alot of weight with all that build up on the arms and chassis.
http://i181.photobucket.com/albums/x...e/DSC00434.jpg
http://i181.photobucket.com/albums/x...e/DSC00435.jpg
http://i181.photobucket.com/albums/x...e/DSC01185.jpg
http://i181.photobucket.com/albums/x...e/DSC01188.jpg
#23
++1 for the DE. I used to make my own, but the DE's are strong, and curved so they do not bind or bite into your body.
Mud is mud, if it is real mud! Take a look at Frank L's profile pic. You are not going to do anything about that type of mud. But, it is better (imo) to have that mud on the guards than on you shocks, cvds, and pivot points.
For regular "wet" conditions, I have tried spraying them with WD40 and Kal Gard "Prep and Shine" and that seems to help keep a lot of it from sticking (note: if you try the Kal Gard, make sure the body is off the car when you spray it, that stuff and lexan do not get along).
But for really sloppy mud, it is basically pick your poison and where you want the mud to collect.
#24
If it's wet and muddy run 'em. No real point running them in the dry. . . . . i did run them when it was dry and it must have been a mental thing but to me it felt as when jumping the nose would go up more with em on (or more likely, i was still learning to drive the car as it was my first season n nitro offroad) . Daft i know but it's probably the mind playing tricks
#25
Yeah i'm still undecided on wether to run them or not and wether to take them off my buggy or not. On one hand i can see them causing some drag, but how much drag is questionable. Also like i said before how much of that dirt or mud would just pass through instead of getting stuck to the guard?
Imo its too much to debate for a $6 part, so for now i'll just not run them and maybe take the set off my buggy to see if it flies any better the next time i can make it out to the track. I use shock socks so they don't collect much dirt as it is, but i'm just curious as to how much it protects the rear end. The track i run at doesn't have any loose rocks so its not a big deal either way.
#26
does your track have a 500' straightaway ? Wind Drag is the last thing you should be worries about.
#27
Wing drag? Maybe not. But they sure do collect mud that would otherwise leave the car. They add weight, no question.
#28
this run them, even if the track is dry it still keeps the shocks and bearings cvd cleaner and, you never know when they water the track sometimes people can get overwelmed with it and causeing puddles .
now about drag its offroad not oval onroad racing lol.
#29
no its in your head your seeing things lol.
#30
I had a set sitting in my box for a long time and then we got a lot of rain and i ran once one the track and the rear arms and shafts were covered with mud. have put them on and havent looked back ever since. Plus i think they keep things cleaner. Just have to wipe off the guard instead of getting inbetween the drive shaft and rear arms.
