FS O'Donnell Z01-SG Team Brand New Built never ran!
Brand New built, never ran O'Donnell Motor and Electronics were mounted and I decided to go a different direction. Buggy never touched the ground. Has Just Cranford's setup on it.
O'Donnell Z01-SG Team "Second Generation" 1/8th Off-Road Competition Buggy Kit
This is the O'Donnell Z01-SG Team 1/8th Off-Road Competition Buggy Kit. The original Z01-B set the standard. The Z01-B Team raised it. And now, the second-generation Z01B-SG lifts it higher than it's ever been before. O'Donnell engineering has found no fewer than 15 ways to improve the platform and help you finish first. They include more carbon-fiber and machined, 7075-T6 aluminum parts to boost strength and reduce weight. The shock towers, rear arms and rear hub carriers have been redesigned for improved suspension geometry. And the body and side pods have been narrowed to minimize the impact of wind and drag. In the world of 1/8 scale nitro racing, you never settle for good enough, because there are always new ways to go faster and drive harder. O'Donnell engineers have found them and included them all in the Z01B-SG.
The second generation of winning is about to start. Be ready to meet it, with the Z01B-SG.
New SG (Second Generation) Team features:
Lighter, stronger 7075-T6 chassis plate with improved weight distribution
Improved suspension geometry from updated rear arm, rear hub carrier and front/rear shock tower designs
Stronger CVA axles with large 3mm cross pin
Stronger carbon-fiber front plate
Redesigned carbon-fiber center diff top plate
Carbon-fiber servo tray
Reinforced diff cases
4.3:1 diff gears
Narrow side pods
7075-T6 billet aluminum torsional front torque rod
7075-T6 rear torque rod with glass-filled rod ends
Sleek, narrow body
Improved droop screws
There's a time to change — and a time not to change. And you never change what works. You keep your successes and build on them. And the features below are just that: building blocks for your next win.
"Standard" ZO1B Features:
Threaded, big-bore oil shocks with 4mm, micro-finished, super-alloy shafts and hard-anodized aluminum bodies.
Dual brake system with adjustable front/rear bias, over sized brake discs, heat-treated hardware and spring-steel alloy pads
Captured, micro-finished, super-alloy hinge pins
Dual, high-volume fuel filters
Low-profile, oval air filter
3 front & rear sway bar sets
3 precision-wound spring sets
Lightweight aluminum heat sink/engine mount
Dish-style wheels
Covered wheel nuts
Race-legal fuel tank with splash guard
High-performance, rubber-sealed premium bearings
Countersunk hex-head hardware
Sealed receiver and battery boxes
Includes low-profile polycarbonate body, molded nylon wing and dish wheels.
Specifications:
Length: 20" (510mm)
Width: 12" (305mm)
Height: 7.5" (190mm)
Weight (approx): 7 lb (3,175g)
Wheelbase: 13" (330mm)
F/R Track: 10.25/10.5" (260/275mm)
Includes:
Complete chassis
Clear polycarbonate body
Nylon wing
Wheels
Clutch
Air filter
Dual fuel filters
Shock wrenches
Manual w/set-up tips
COMES with 7 Hole Pistons!
PRICE DROP! $410.00 shipped lower 48
4.3:1 diff gears
Narrow side pods
Sleek, narrow body
Dish-style wheels
Covered wheel nuts
Specifications:
Length: 20" (510mm)
Width: 12" (305mm)
Includes:
Complete chassis
Nylon wing
Wheels
Clutch
Air filter
Dual fuel filters
Shock wrenches
Still available!
would you like to trade
ive got two jammin x2's truggy and buggy let me know if you wanna work something out i've posted the link below
http://www.rctech.net/forum/r-c-item...ggy-f-s-b.html
