Team Durango DEX410 Buggy For Sale >
Old 08-22-2010, 02:49 PM
Default Team Durango DEX410 Buggy For Sale
Ran twice no long have the time for RC. Purchased everything new wheni built it. Best of everything.
R5 Pro Tekin 5.5 motor. Spektrum Micro receiver. Airtronics 360 series metal gear servo. IP 4200 batteries. This setup new is well over $1,200.00
Asking $850.00 Local pickup is available and preferred. ($25 shipped to U.S.)
I also have over $400.00 in spare parts for this car that i will post separately. Let me know if your interested.
Goober9941 is offline
Old 08-24-2010, 08:40 PM
Old 08-24-2010, 08:59 PM
Durango RC parts
$300 (+$10 shipping in the U.S.)
TD330009 – Rear Bulkhead Set $5.00
TD320005 – Battery Holder Set (Lipo) $4.00
TD330001- Plastic Ball Joint Set: Complete $12.00
TD330005 – Suspension Arms Rear: 1 Pair Left and Right $7.00
TD310038 – Cover Set: (Front Diff 1pc, MID Drive Cover 1 pc) $3.00
TD310023 – Driveshaft Boot Wheel Axle (2PCS) $3.00
TD330033 – Pivot Ball A- Type (4pcs) $7.00
TD310015 – Slipper Outdrive Rear (1pc) $5.00
2 - TD330030 – Shock O-Ring (8pcs) $1.50x2 = $3.00
TD310039 – Gear Box Set: Front and Rear $5.00
TD710001- E-Clips for Diff 4mm ID (10pcs) $2.00
4-TD340008 – Front and Rear Hub Set (Front 2pcs, Rear 2pcs, 0 degree) $7.00x4= $28
TD310029 – Wheel Axle: REAR (1pc) $6.00
TD310033 – Shim 10x12x0.1mm (10pcs) $2.50
TD390025 – Roll Pin 1.7x10mm (10pcs) $2.00
TD310036 – Mid Drive Shaft: Longlife Steel (REAR 1pc) $7.00
2 - TD330011- Shock Cartridge and Piston Set (4pcs) $4.00x2= $8.00
TD712002 – Pivot Ball Bushing: Conical 7x3x2mm (10pcs) $8.00
TD310031- Slipper Clutch Pad (2pcs) $7.00
TD330017- Shock Boot: REAR (2pcs) $3.00
TD340004 – Steering Knuckle Bushing (4pcs) $ 2.00
TD340007 – Servo Saver Set $3.00
TD330018 – Shock Boot: FRONT (2pcs) $3.00
TD330003 – FRONT Bulkhead Set $5.00
TD330026 – Suspension Arms FRONT: 1 pair Left and Right $ 7.00
TD310024 – Driveshaft Bushing (2pcs) $3.00
TD709002 – Shim 4x8x0.3mm (10pcs) $2.00
TD310035 – Mid Drive Shaft: Longlife Steel (FRONT 1pc) $7.00
TD330013 – Shock Cap and Spring Bucket Set (4pcs) $4.00
TD310018 – Mid Drive Clamp (1pc) $2.00
2 - TD330028 - Shock Cap O-ring 10x1mm (4pcs) $1.50x2= $3.00
TD230001 – Full Tuning Spring Set ( FRONT – All 8 Pairs included) $20.00
TD230002 – Tuning Spring Set (REAR- ALL 8 pairs included) $23.00
2- TD310026 - REAR Driveshaft Steel (1pc) $9.00x2= $18.00
TD709004 –Caster Block Spacer 3x8x2.00mm (4pcs) $5.00
TD310021 –Differential Case (1 set) $3.00
TD330042 –Shock Shaft: FRONT (44mm 2pcs) $9.00
2 - TD711001 – X-Ring for Diff 8.8mmDia (10pcs) $4.00x2=$8.00
TD330034 –Pivot Ball B- Type (4pcs) $3.00
2 -TD715001 –Lock Nut M3: Low Profile (10pcs) $3.00x2=$6.00
2 -TD320006 – Battery Holder Snap Pin (3pcs) $2.00x2=$4.00
3 - TD310025 – FRONT Driveshaft Steel (1pc) $9.00x3=$27.00
TD330035 – Pivot Ball C-Type (4pcs) $9.00
2 -TD310028 – Wheel Axle: FRONT (1pc) $6.00x2=$12.00
TD310022 – Driveshaft Boot Outdrive (2pcs) $3.00
TD310020 –Spur Gear 87T ( 48DP) $4.00
TD320003 – Bumper and Skid Plate Set $4.00
TD709009 – Shock Piston Washer: Chrome 2.5mmID (10pcs) $2.00
TD330043 – Shock Shaft: REAR (52mm 2pcs) $10.00
4 - TD708002 – M4 Lock Nut for Wheels (10pcs) $2.00x4=$8.00
TD310034 – Shim 10x12x0.2mm (10pcs) $2.50
TD330007 – REAR Hubs: 1 pair, LEFT and RIGHT ( 1 degree TOE-IN) $4.00
TD330036 – Pivot Ball D-Type (4pcs) $5.00
TD330037 – Suspension Arm Pivot Ball (8pcs) $10.00
TD330027 – Shock Stopper: Rubber (4pcs) $2.00
TD330024 – Shock Tower Carbon Fibre: REAR (4mm 1pc) $25.00
2 - TD330029 – Shock Nut O-Ring 12x1.5mm (4pcs) $1.50x2= $3.00
TD709001 – Shim 5x10x0.5mm (10pcs) $2.00
2 - TD715002 –Locknut M3: Standard (10pcs) $2.00x2=$4.00
TD320009 –Battery Holder Pin $1.00
TD310027 –Gear Input Driveshaft (1pc) $7.00
TD709003 –Caster Block Spacer 3x8x1.00mm (4pcs) $5.00
TD402001 - DEX410 Clear Body Set $20.00
Old 08-25-2010, 04:14 AM
rraden's Avatar
Trader Rating: 259 (100%+)
Interested in selling the roller only?
rraden is offline
Old 08-25-2010, 06:43 AM
Trying to sell as is. If that doesn't work out i'll sell everything seperately. Keep checkin in.
Old 08-25-2010, 08:03 PM
bump
Old 08-26-2010, 06:04 PM
bump
Old 08-28-2010, 04:22 PM
The best work of art ever in a 4 wheel and no one is interested yet???
Old 08-28-2010, 05:45 PM
drbelleville's Avatar
Trader Rating: 13 (100%+)
Hate to say it, as nice as the buggy is, hard times right now. I am sure many would like to have one. As much as a pain it seems, your best bet may be to part it out. Spare parts, batteries, roller, etc.
drbelleville is offline
Old 08-28-2010, 06:33 PM
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I Pmd you about some parts but never got a response back
Dlewis4 is offline
Old 08-29-2010, 04:39 PM
That parts list of your is too small id rather keep it. Trying to sell as a whole if possible.
Who wants to buy the car as a roller and all the parts for $650.00? (+ shipping)
Old 08-30-2010, 08:29 AM
bump
Old 08-30-2010, 08:37 AM
Suspended
Trader Rating: 42 (96%+)
Good luck with that man. people can buy this new for 350.00
I understand you got all these parts, but no1 will buy the whole.
try to seperate.
PsycoB4 is offline
Old 08-30-2010, 09:43 AM
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
try to seperate.
The DEX410R is $350 this is the pro spec car and sells for $650. amain sells both. I think $650 with all those spares is a pretty fair price
PaintingRoly is offline
Old 08-30-2010, 10:24 AM
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool I'll....
Are u doing trades. I'll make u a crazy deal....
Rideordieguy1 is offline
