Esc Capacitors
#136
Trader Rating: 22 (100%+)
thats very interesting, i might try an original cap for my cyclone tc2 andsee what happens, i "dented"the last one, didnt know they where that soft ive been running a big bastard of a cap because its all i had.
#137
I have some 6.3v caps. Can I use those?
#139
Cool Got it...thanks for the reply.
#140
i 've been posting in the xxx-s thread about this, i'll switch over now. I run the regular cyclone, but have a tc2 that doesn't work. Could i keep the stock(smaller) cap. and solder on the tc2(larger) capactor, to end up running two on the same esc, one big, one small. What would this do, would it help, hurt?
#141
Originally posted by was ist los?
Hey AzNDRAGster, noticed you're from SF. Where do you race? RC Tech?
I have an older ESC that doesn't have a capacitor and I want to install an capacitor, where would I have to solder it?
#143
can anyone clear this up for me, after reading this entire thread i have read many conflicting conclusions.
If i was to run a 10,000 microfarad capacitor, whats the difference between this and a 1,000 microfarad capacitor? Punchier? Smoother? Cooler Esc?
Thanks.
Thanks.
#144
Thanks.
Thanks.
#145
Thanks.
Thanks.
so 10,000 (more punch) will be a noticable diffrence with just 1000 (less punch)
but then
the higher ther the voltage the capacitor can handel, the less punch.
so a 10v will have more punch then a 16v capcitor.
so i recommend a 10,000 uf capacitor with a voltage around 10v
or if you cant find a 10,000 uf capcitor get 2 4700 capcitors with a voltage of 10v each.
i hope this helps
#147
thankyou very much this helps HEAPS
#148
Originally posted by rc-zombies
You can get 2 10,000uF 10v on ebay for about $10.0
cant quiet remember
2 10,000 uf capacitors.......
might as well just get a 22,000
i cant remember the site but they have on there its CRAZY big
#149
http://www.rczone.net/modules.php?na...wcontent&id=22
here...!!! found it
check out that big blue thing
here...!!! found it
#150
makes things easier
