Kinetix RC Batteries
#271
Originally posted by Team-RTR
hi ron, i recently purchased 3 kinetix stage 3 packs. the first 4 or 5 charges all packs charged quite well, peaking with about 3600-3700 mah. after about 6 runs 2 of the packs are peaking at about 3100mah-3200mah but peaking with good voltage. each pack has been discharged after each run at 20A on my eagle CDC. i do not have a equalizer tray so i can not equalize my packs. can you please point me in the right direction. thankyou
#272
Team RTR - Atomic has been at the Snowbird Nationals the past week. He will be arriving back home today or tommorow and I am sure he will get with you then.. please be patient as I am sure he can take care of what you need when he gets back..
#273
Mr atomic, i emailed you a week or two ago in regards to some packs that are not behaving as they should and you still have not replied to my email, could you please help me rectify this problem as the packs have only been used for about 3-4 race meets.
Later,
#274
RTR - Do you have a way to put a cycle on the packs to get the #'s. Can you tell a difference in performance on the track? . Have you tried to tray they to equilize them yet?. Sorry about the delay , I sent a reply to you through email , but it got returned while I was gone to the Birds.
#275
Ron, great job at the Birds!!! I was cheering for Ray, but I like Cuffs a lot, too so it didn't matter who won. You and Ray did a gre4at job on his cars and considering he was running a XXX-S with worn out shocks and a simple bacis carpet setup, you were definately the underdogs!!!
Not to mention you had a number of other drivers running your products. I know you can't mention some of the names, but who were the others?
#276
Yea good job at the Birds Ron. Hey you racing the SWCS this year or what? If so what car, tires, engine, all that stuf?
#277
#278
Ron,
Thanks again for all your help at
the "Birds".
I just need to find .02 a lap,
how much $$ is that??
Later,
Bill
the "Birds".
Later,
Bill
#280
Bigdog- 1/10 TC Stock "A" Main Guys running KINETIX
2nd Raymond Darroch
4th TJ Bradley
6th Jeff Dayger
***one other I cant mention***
1/12 GTP Stock "A" Main
TQ and 5th Jeff Dayger
9th Raymond Darroch
***one more in here also ***
19Turn Expert "A" Main
***One in this main also***
19Turn Sportsman "A" Main
5th TJ Bradley
I would like to thank everbody that ran Kinetix at the race .
Texasracer - I will be running some of the events.
Bsydor - Thanks , I had a bottle of .02 in the room , you should have asked.
Tres - Thanks
Team-RTR - Most sound typical , I would suggest using the Novak tray or another every time you run the cells . This tends to help the cells in the pack stay in tune with each other . It sounds as if this is what needs to be done . Try this for a couple weeks and let me know how it goes.
2nd Raymond Darroch
4th TJ Bradley
6th Jeff Dayger
9th Raymond Darroch
5th TJ Bradley
Tres - Thanks
#282
good job at the Birds Ron,
you guys really had it together EVERY SINGLE kinetix driver had rip!!!!
looked king of like the mafia thoughHAHAHAHAHAH
see ya at the nats
Mo
see ya at the nats
Mo
#284
I am going to make myself close enough HAHAHAHAH
I plan to go up there next weekend to get on the track,
I will let you know how it is.
Mo
Mo
#285
Ray Darroch Edition
This is an exact replica of the motor used by Raymond Darroch to win the Novak US Indoor Touring Car Championships. Alot of time has been put into making sure this motor is perfect. Each brush is broken in differently and ready to go. Bushings are perfect , hoods are perfect. Smaller OD shims are used for the least resistance.
Binary based ROAR legal stock motor (higher rpm ,more top speed)
The motors are dyno tuned using a Robitronics Dyno with print out included in each motor.
High performance motor brushes used for maximum performance.
No need to break the motor in, it has been done.
Magnets zapped to center poles for perfection and insure the stongest can possible.
Armatures shimmed to center of magnetic field.
Brush hoods aligned for perfectly square brush contact.
Armatures trued with a diamond bit lathe.
Springs tested and tweeked for best performance.
Bushings pressed and checked for minimum resistance.
