Making my buggy lighter.
Gday all.
I am about to buy a factory team b4. And wondered where I can take some extra weight out of it from.
I heard that people mill out there chassis. What are your thoughts and has any body done it.
Thanks in advance.
Thanks in advance.
2wd off-road buggies really handle a little better with a bit of weight in them, which is why team guys don't have a problem with running a few aluminum parts here and there.
Milling out the chassis does almost nothing in the way of removing weight, but it does lower the weight that sits in the chassis.
The easiest way to remove weight is to put it on a hardware diet; replace all the stock steel screws with titanium and aluminum.
Is lunsford the best person to buy screws etc from.
I know that you have to be a certain weight but if you can put the weight where you want to it would be more balanced.
Lunsford is a great place to get screws.
It's not weight balance that I'm referring to..simply a heavier car. Weight slows down the reaction of the car to driver input and track variables.
Yeah I didn't think of that.
But if it was lighter he wouldn't catch me.
I race my buggy in the stock class, so every advantage is crucial. I love the blue stuff...so I've got
-Trinity Blue aluminum screws throughout (except on the shocks)
-Lunsford titanium hinge-pins (instead of the steel ones)
-Robinson Racing aluminum pinion gears
-Trinity lightened slipper plates
I don't have any of the arm mounts or carriers in aluminum, thats just added weight. If you are going to mill a little out of your chassis, do it around the outermost edges. Physyics says that if you take the weight out of the outside and either remove it or bring it to the center, the object (in this case your car) will rotate quicker. Basically, mount your electronics closer to the battery tray. If you add weight, a good place to do it would be right under the servo horn....yes, it'll fit. It could also fit on the battery strap (keep the weight in the center). Losing weight is all in the little things.
OK I just ordered a full set of titanium screws and hinge pins from lunsford. I have A quantim 2 speedo and lightened slipper pads.
I tried to find a lightened top shaft but can't find anybody that makes them.
Where else can I save weight.
Do the plastic out drives stand up to the task.
I thought that maybe they would break
It depends on the track layout. I always run stock, so its not as bit a deal. But I wouldn't trust them in mod. Generally, they'll be fine and do hold up to a lot more than you'd think. If your track has a massive drop off (jump to flat landing) and lots of really technical "hard on the car" kind of layout....then stay with the steel ones. If your track is realitevly smooth and flowing, then plastic is the way to go. Ryan Cavaleri runs plastic outdrives but with the savers and he can get away with it in mod buggy and such.
here are the molded lightweight outdrives: Lightweight Outdrives
You may also wanna get the milled motor mount too.
