Ok, put in new servo, now another problem with steering. >
Old 05-30-2004, 06:39 PM
Default Ok, put in new servo, now another problem with steering.
Ok recently i got into alittle accident, so I bought a new servo. Now the problem iswhen you turn left and let go, the wheels center themselves fine. But when I turn right and let go, they stay angled to the right, any idea what it could be? Actually, when I turn right and let go, the wheels stay as if your turning straight right. By the way, this is for my Team associated tc3. All help is appreciated.
klonoa is offline
Old 05-30-2004, 07:03 PM
klonoa
check over all of the pivot balls on the front end .. it sounds like you might have have one thats bent and binding up the suspension when turning right ... check it over and see .. that might be the problem ... or it might be a bad servo from the manufacture ... it happens ... to check that disconnect the link from the servo arm to the steering rack and then see if it centers easily both directions ... give those two things a check ...
have fun racing
E
roddude65 is offline
Old 05-30-2004, 07:37 PM
I checked it, everything seems fine. Nothing broken, everything is connected. Maybe I didnt put the angle right on the servo?
klonoa is offline
