Team Associated TC6 Thread
#9286
#9287
If you track is as big as aldershot (uk) then u might want 3.2-3.5 which you would be better off with a 66t sper and carry pinions 39-42t
Pinion Fdr on 66t sper
39t 3.38
40t. 3.30
41t. 3.22
42t. 3.14
This is what I ran on my tc6 which internal ratio is also 2.0
#9288
That would be a very large sper and pinion might not fit
39t 3.38
40t. 3.30
41t. 3.22
42t. 3.14
39t 3.38
40t. 3.30
41t. 3.22
42t. 3.14
#9289
I can no longer find the original website, so I can't take the credit for these, but these tables show what spurs and pinions fit in a TC6 for 48 and 64 pitch:
http://deckjockey.com/tc6/wp-content.../08/gear64.png
http://deckjockey.com/tc6/wp-content.../08/gear48.png
#9290
Thanks Nick... some folks seem to be under the impression that only one combination will yield the FDR desired.
How bout 226t spur and a 123t pinion? Will that fit? 32 pitch...lol
It's all about the numerical ratios when it comes to FDR but the pitch will determine the actual diameter of the gears, given their tooth count. That's where fitment comes into play. The original suggested gear combo was for 64 pitch not 48 and it was presumed that it was fairly obvious.
#9294
48pitch is what has always came on all brands i have seen apart from tamiya so with out knowing that how could one tell
plus 48pitch 92sper and 50 pinion aso gives you the fdr 3.68
#9295
Since we are talking ratio's and gears and stuff. What is the general opinion on gearing sizes. For example is it better to run the biggest or smallest spur gear possible then choose the pinion that gives the desired ratio. Or does it matter?
An example would be is there a differnce in running a 102/51 vs. 98/49 vs. 94/47? The ratio of these gears is all the same but will they feel or function differently? As in speed, temp, punch, etc.
#9296
hey rich,the largest 48dp pinion i can get to fit is a 43,i can just get a 44t on but i cant get to the motor screws,so how do you get the bigger pinions to fit?
#9297
If I run the 44t maybe a ball ended Allen key ?
#9298
#9299
I suppose the rule of thumb is: If we are talking about spur gears over 90t, it's likely 64p with regards to touring cars.
Yes, 92 divided by 50 then multiplied by 2 does come out to about 3.67 and you have backed up my example that the math all works out the same regardless of the combination.
That was my point exactly.
#9300
I could never really tell the difference in car performance when I change the shock angle. What differences should I see on stood-up vs lay-down on lay-down on the tower because accounts differ... does standing up the front shock give you more turn-in and sstanding up the rear gives more rear bite? I've never really gotten a hold of this...
