Team Associated TC6 Thread >
Like Tree20Likes
Old 01-06-2013, 02:20 AM
  #8536
wtcc's Avatar
Originally Posted by 2canSAM
I just picked up a T6 roller in a trade and it has the VCS2 shocks on it. I attempted to rebuild them last night and it was rather messy Does it mess up the top foam pieces if they get any oil on them?
Doesn't matter at all. Working with shocks is always messy. The times I rebuild my shocks without getting my hands and the shockoutside oily are very very rare. Just remove the oil from outside surfaces. Otherwise the dust and small pieces will love to stick there.
wtcc is offline
Old 01-06-2013, 04:25 AM
  #8537
kewdawg's Avatar
Originally Posted by wtcc
Buy the #31360 TC6.1 Steering Blocks, the #31358 TC6.1 Caster Blocks, four 5x10x4 bearings and the #31370 TC6.1 Axle Crush Tube. Then buy all the DCJ, pins and hexes from RSD...
I think I heard that Tamiya bladders fit as well, but that was two years ago...
Today the Zeppin C-Hubs arrived from Finnland:
Good manufactoring quality as far as it is visible. They look a little weak. We will see if they can take some hits.
Unfortunately the UPS-man came late so I couldn't test them today. So you guys will have to wait at least one week for an inside report. Before I will post some more pics with the C-Hubs on the car and a feedback how they fit (slop, DCJ-fitting, and so on...).
Thanks for the info.
I'm putting the Zepplin c-blocks thru the paces this weekend at a 2 day event. They are holding up very well(2nd race weekend usig them). Installed the RSD DCJs without any mods. Installed RSD bladders and using soft RSD Spring Set. The car is consistent and smooth. Going to install the belt tensioner today. Looking to get the harder spring set.
kewdawg is offline
Old 01-06-2013, 09:08 AM
  #8538
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Im looking at reflex dcj shafts and there are 2. Short and long axle. Should I get the short ones? I have a tc6 but already have 6.1 hubs, knuckles and crush tubes. Do my original dog bone blades fit them or do I need to get spec-r?
Mr.juarez is offline
Old 01-06-2013, 09:19 AM
  #8539
CristianTabush's Avatar
Trader Rating: 13 (100%+)
If you are running the 6.1 steering blocks, get the narrow version. Your blades will be fine, but you will need new hex hubs and roll pins.
CristianTabush is offline
Old 01-06-2013, 10:17 AM
  #8540
Mr.juarez's Avatar
Im not at the moment but they are ordered. What hexes and pins do I need now? Thinner ones? Crap! if you guys carry them please link them all i see the site has 4-5mm ones. I have the stock ones but have 3racing 4mm one as well.
Thanks man
Old 01-06-2013, 11:40 AM
  #8541
wtcc's Avatar
Thanks man
Calm down
Both hexes will work. I would recommend the 5mm ones. These are the same size like the original TC6 hexes. The 4mm ones are a tuning option for a more narrow car. If you are unlucky the wheels will scrub on the suspension arm...
wtcc is offline
Old 01-06-2013, 11:51 AM
  #8542
Mr.juarez's Avatar
Calm down
I am calmed down
So my current ones are ok then, sweet what about pins? I dont want to narrow it as I have 3mm offset wheels and 6mm in the rear.im happy the way it handles and where its at. Thanks for clarifying on hex
Old 01-06-2013, 12:14 PM
  #8543
wtcc's Avatar
If you mean the original hexes then it was a misunderstanding. The AE hexes will not work because the DCJs use thicker pins! I meant the RSD hexes in 5mm. Maybe the 3racing hexes work if they are for 2mm x 10mm pins.
wtcc is offline
Old 01-06-2013, 12:31 PM
  #8544
Thinking about selling my TC6.1FT roller, partial WC conversion, lots of RSD parts and other upgrades. Never run, includes all original parts. PM me if interested.
Vostok 7 is offline
Old 01-06-2013, 01:14 PM
  #8545
wtcc's Avatar
I installed the Zeppin 4.5° C-Hubs now.
The assembly went good. Shims are needed to make it slopless. I used 0.2mm for the outer suspension pin an 0.5mm underneath one of the caster block bushings. Now it is perfect like it never was before! I just hope the parts are durable!
wtcc is offline
Old 01-06-2013, 07:44 PM
  #8546
JFuel11's Avatar
Trader Rating: 152 (100%+)
Quick Questions...
I noticed on a few TC6 chassis that the steering blocks are flipped over with the ball stud pointing down. Is this the way the TC6 was built or is this a tuning option people are/were doing? I have not messed with it at all on my tc6.1, any help would be great.
JFuel11 is offline
Old 01-06-2013, 08:47 PM
  #8547
Mr.juarez's Avatar
Yes I was referring to the ae ones, but I see what you mean now about the pin.
http://www.reflexracing.net/RSD-DCJ-...cs_p_1124.html
And this
http://www.reflexracing.net/RSD-DCJ-...ir_p_1125.html
Old 01-06-2013, 08:56 PM
  #8548
DARKSIDE's Avatar
Originally Posted by JFuel11
Quick Questions...
TC4/6 upside down...TC5/6.1 flipped...not sure why?...every other car...lol
DARKSIDE is offline
Old 01-06-2013, 11:37 PM
  #8549
98NYFINESTVETTE's Avatar
Hello all, I just purchased a lightly carpet raced TC6.1.
Can anyone guide me in the right direction about what I should do in regards to upgrades? I having been reading to the point where everything is blurry. In the early days, I read that people where replacing the diffs. Thinking that this model has been out for awhile now, most if not all would or should have some advise. It is a roller. So I will be building it over the winter. Looking to race outdoor with it. Not much of the indoor person. I also race SC10 4x4 off road outside.
Thanks again
I have to say the posts are very informative. To be honest, if this deal did not come around, I have been looking at the T4. As mentioned many times, both vehicles will get you around the track - it comes down to the skill of the operator.
98NYFINESTVETTE is offline
Old 01-07-2013, 01:10 AM
  #8550
some one asked about the mod i did to mount the cso servo mount
Edwin Pibal is offline
