Team Associated TC6 Thread
#5701
You could also partially drill a larger hole in the A Arm, that will free up the droop screw, but be warned an oops here could cost u , but keep in mind it will loosen up over time
#5703
You can also pre-tap with a good steel screw, apply silicon or chapstick to droop screw before installing.
#5705
96 is the spur of choice for 17.5 blinky. 96/51 is a 3.76, which is the same as your 90/48
#5710
I mean with the gearing I had it wasn't terrible slow but I think I was just under the average speed. I'm guessing outdoor I'll have to gear up some also
#5711
Yes Norcal, I think with my 48/100 it is about 4.00 and the motor barely gets warm and it could be faster on straight
