Team Associated TC6 Thread
#1937
Had no problem uses upper most hole in the front.
#1941
#1943
Also, As far as spacers go I have found the Mugen spacers at amain pretty cheap and larger in diameter. They work great for toe spacers/suspension arm mount spacers. The actual wheel base spacers I am using stock but I think my TOP stuff fits.
#1944
Does anybody know where i could find a chasis protector so i dont scratch the crap out of the car on asphaltthis season?
#1945
tc6
well my build is on hold ....im missing a few diff parts and a chipped chassis ..called the hotline for associated sent them some pics and is now waiting for the missing parts to arrive .
pyro search around the airplane section of your local hobby shop for very large decals sheets and trace the chassis and you can make your own
#1946
I think j concepts has chassis protector.
#1947
For arm mount, wheelbase and toe adjustment spacers, I use 12r5 front bulkhead shims. They come in 2mm, 1.0, and 0.5mm and are also blue
#1948
I have bad luck with my TC6 ... found a dog bone that has a thicker diameter and cannot fit into the UJ cup, and then found that one of the outer a-arm pin has a smaller diameter than usual and as such the c-hub is not fitting tightly on the a-arm ... not sure if you guys also find same problem in some of the kits sold ?
#1949
I sent an email yesterday and received a response within 30 minutes.
