How Do You Store Rubber Tires? >
Old 05-23-2004, 09:49 PM
evaa's Avatar
Default How Do You Store Rubber Tires?
a simple question, how do you guys store your rubber tires? i've heard of some racers applying traction compound before they store their tires to keep them fresh and prevent cracking. any secrets?
evaa is offline
Old 05-23-2004, 10:00 PM
Yup and I use Integy tire tubes. They seem to trap the moisture in and keep the tires from drying out.
NismoSkyline17 is offline
Old 05-23-2004, 10:04 PM
tornado
Guest
Posts: n/a
Default Re: How Do You Store Rubber Tires?
Yeap I've heard of that too....I've seen some guys would wet the newspaper with traction compound to wrap the tires and keep them in a ziplock bags until the next rubber burnin' time
Old 05-23-2004, 10:07 PM
after i'm done with my runs, i just clean the tires with WD40 and store it with a Zip Lock sandwich bags.. works for me!
rcprix is offline
Old 05-23-2004, 10:10 PM
evaa's Avatar
wow thats great, keep it comming guys, by the way, we run sorex 40s here, track temp ranges from 50 to 70 C.
oh, another question, wont my tires overheat if i apply traction compound when i use them after storage? or does the traction compound take effect a few mins after u apply them?
evaa is offline
Old 05-23-2004, 11:05 PM
Neil Rabara's Avatar
Traction compound softens the rubber. If you leave it on too long, the rubber gets extremely soft. Great for cool or cold days with low bite, not so great for warmer or hot days. I store my tires in zip lock bags with a shot of motor spray before sealing them.
Neil Rabara is offline
Old 05-24-2004, 12:02 AM
evaa's Avatar
ok, so the traction compound will soften the tires when i store them, but i might have problems when i use them again especially in the hot weather, am i correct?
so is it a consensus that storing them after applying traction compound is not good (in hot weather)?
evaa is offline
Old 05-24-2004, 12:59 AM
Hixsy's Avatar
i clean them after the race, red dot them and place them in a sealed glad wrap bag.
Hixsy is offline
Old 05-24-2004, 01:32 AM
Soviet's Avatar
I clean 'em....sauce 'em and slap them in a sandwich bag as well.
Soviet is offline
Old 05-24-2004, 01:42 AM
Cole Trickle's Avatar
And what do you guys do, if you're not allowed to use traction sauce? Just put them in an air tight bag?
Cole Trickle is offline
Old 05-24-2004, 01:52 AM
evaa's Avatar
do you really need the air tight sandwhich wrapper? i use the hpi tire bag, it fits 4 tires and seals them using velcro, but im sure its not air tight, will that matter?
evaa is offline
Old 05-24-2004, 01:56 AM
tornado
Guest
Posts: n/a
Wow .....it gets to soft eh..... keep that in mind. 'cos some of these drivers just tell you what they do but no further explanation why they do it.
Old 05-24-2004, 01:57 AM
tornado
Guest
Posts: n/a
I'm doin' this too and it works like a charm.
Old 05-24-2004, 02:27 AM
Store tires?????
I thought you guys didn't stop driving until the tires were worn out.
andsetinn is offline
Old 05-24-2004, 02:52 AM
tornado
Guest
Posts: n/a
Originally posted by andsetinn
Store tires?????
Oh..now I understand...... those guys who have worn out their tires would wrap them in newspaper soaked with tire sauce so that they have grip in the next run.....
Cheapskate
