SXX Comp and TC Version 2
#272
http://www.redrc.net/2012/02/toy-fair-2012-lrp-sanwa/
#273
There is an upgrade board to be released shortly, I assume they'll offer a fully updated speedo when it's released too
But look in the left hand corner the signage says 2 in 1 mod and stock. This is a HUGEEEEE welcome in my opinion.
Looking forward to them.
Anyone want an Nosram ISTC Ver 2 lol
#275
Hi,
Has anyone tried the V3.0 firmware yet..and is it smoother than the V1.5?..
#276
I have been waiting for a speed control sxx comp v2 that I sent in for repair at the beginning of January .
Called the people that represent lpr in north america and they advised they are waiting for the order to come in . I am trying to be patient but next week it will be a month and a half .
Oh what a beautiful indoor season its been .
Pls LRP I hope you send my speed control soon .
#277
I hope that you at least got some use out of yours before it failed. Mine was an out-of-box failure. I spent $200 on this thing, and I've never even used it.
There are other companies that actually DO service their products in a timely fashion. Next time, my money goes to them.
#278
So whats the general opinion of the new V3 firmware....???
#279
I've seen a few v2's running with modified cap's. rather then a singe lare cap (std) the owners have changed this for three smaller caps?
I guess while the caps are smaller the three would yeild greater capacity while they are smaller so they should discharge faster... what effect will this have on the ESC?
#280
- Emil
#281
Thanks in advance for any help. I have just installed a sxx stock spec in a Losi 22t with a 13.5 x-12. I calibrated it, broke in the diff and tried to set the slipper. When I give it full throttle it cogs severely. It operates perfectly fine if you give it throttle slowly or when the wheels are in the air. It is geared at 8.0:1 using a 3800 2s lipo. This is my third sxx ss esc and the second time this has happened. The first time was in my buggy, but it seems to work fine when I'm on the track. I've tried different sensor cables but no luck. Everything is brand new. For what they cost I can't beleave they would come bad from the factory. What am i doing wrong?
#282
Check out this post from Matt Murphy about some electronics not playing well together
http://www.rctech.net/forum/team-com...ml#post8660315
#283
What servo are you running ?
#284
Only other advice I can offer is make sure you have the 4dot insert in, but that is the way they come, so it should be there.
You may also try to clean the preci sensor with motor spray, I have repaired other brands by cleaning the sensor board.
Good luck, bummer about the cogging.
#285
disconnect everything from the Rx except the ESC and test
try a different motor and sensor lead.
this should not be necessary but do a 'hard reset', its in the instructions.
Check and apply currnet/uptodate firmware
