USGT
#2208
How about the HPI GT wings? Even if they are under 10mm, they look like they have a huge chord.
http://www.hpiracing.com/en/part/85288
#2209
#2211
I believe the point of the weight rule is to allow some parity to exist with the older cars, to create an equalizer of sorts. Stick on weights (used for tire balancing) are cheap and common. You can get some better looking stick-on weights from most hobby shops. Hth or is the answer you are looking for.
#2212
#2214
What Dizope is saying that is adding 100grams of weight or more on a modern car? That is 10 or more 10 gram wieght's it is hard to find the space for that many weights in a modern car the deck on my 417 is full of electronics batteries etc. The belt runs down the center and the space for weight there is limited.
#2217
#2218
Got it, thanks. I'd like to see the tungsten weights you are referring to. One of the cars I run is a Top Photon and it comes with a tray that acts as a lipo holder. The tray is perfect for adding lead weights, that's what it is designed for basically. You could probably add it to any car with just a bit of drilling. I had a spec-r I ran in VTA before the photon and it was a challenge for sure, I resorted to sticking weights to the pack itself, on the front bumper, wherever... I'll look up the weights you are talking about if they are a lot heavier for the size.
http://www.pinewoodpro.com/pinewood-...en-weights.htm
#2219
may not be the exact ones you were talking about, but I found these with a quick google search
