TRX 2.5 not idling...
i've got a problem.. i've tried starting my TRX 2.5, and it spurts goes high then dies.. doesn't idle.. i tried warming the glow plug and starting it, and it's idled.. and i pull the plug wrmer off, it idles for like 10 seconds then dies... Can anyone help me?/
i gues si'll have to make another trip to the store, i replaced the plug wire as well. so i should buy a the 3230 because i jsut rebuilt the engine? would you happen to knwo the stock nozzle settings for the TRX 2.5?
set the idle gap at 1mm high speed needle 4 turns out low speed needle 1.25 to 1.5 turns out. this was a good race tune when i was running them stock settings are 4.5 out on top and 1.5 out on bottom. if at either of these the engine rpms are too high at idle then the gap is too large *or* there is an air leak going on
well im honestly confused on where to adjust the gap, how do i do that? and where would i do that... and well which is the high speed nozzle, im guessing the larger one, and the low speed the smaller one next to it.?
oh boy. read this page 3 times, if you still have any questions after that i will try to help
http://www.traxxas.com/support/index...n&suchbegriff=
