8ight 2.0 Setup for Hard packed with dust
Hey guys I was wondering what you guys suggest for setup for my 8ight 2.0 for a Hard packed track with dust.
I only have a limited choice of tires what would you recommend.
I-beams soft
Calibers soft
Xbt tires i think (Stock race roller tires)
I-beams soft
Calibers soft
I've been having some success with those Exagon and Record Breaker tires from Sweep, in the very same conditions
I ended up using 30 all around for shock oil and calibers for tires and trial and error with the shock adjusters. I placed 2nd,2nd,3rd for qualifiers and was leading the a-main untill my motor mount came loose (i think) and killed my clutch bell thanks for the help guys.
Btw i saw a guy use cityblock ssoft and it looked like it was hooking up the BEST out of all the tires there yesterday. Am I just thinking that or would they actually work excellent?
City blocks and calibers should hook up well for your track conditions. I have used both of them and they felt real good. Just make sure your using the right compound. At a minimum M3 or soft and if you can get away with it, M4 or super soft.
Thanks for the info I have been waiting for cityblock soft mounted on yellow wheels for over a month now. I will place an order for super soft ones monday.
Just curious what conditions / surface do I-beam soft/super soft hook up best in
