Idle gap
Idle gap
Whats the correct way to set and measure the idle gap on a mill that has a carb insert? If anyone has pics that would be great too. I'm a little confused on were to measure at and I just wanted to double check the idle gap.. Thanks for any info.
So just remove the insert and measure the gap and adjust till it's 1mm? Then retune correct?
Thanks for the info, I'll double check it tonight...
.50mm to .8mm is typically a sufficient idle-gap range on almost any engine.
As mentioned, remove the restrictor to set it.
Pick up an Irwin brand, or similar, 61-80 numbered bit set. About mid pack there's a bit size you'll need to set the gap
