Pro Trak
Old 06-16-2007, 10:06 PM
  #511
kiyano's Avatar
If required DLL files is not contained in your PC, this error may occur.
Please download runtime from the following page and install in his PC. Probably a problem will be solved.
http://www.microsoft.com/downloads/d...DisplayLang=en
kiyano is offline
Old 10-27-2007, 01:20 AM
  #512
radio_car_racer's Avatar
just a note to say these are still available from the Manufacturer in the UK if folk are looking for them
radio_car_racer is offline
Old 10-27-2007, 04:08 PM
  #513
Grenade10's Avatar
Trader Rating: 40 (100%+)
Glad to hear of this, as I have two and will not give them up for anything else. Amazing, I still have people who have never seen them work and are really surprised on what the charger will do and what information that it will give you on your batteries. Glad to also see that I can upgrade to Lipo, which I probably will do this next summer.
Grenade10 is offline
Old 12-07-2007, 03:58 PM
  #514
magm20001's Avatar
Hi just wondering how does the Protrak compare to the Spintec ICC?
edit i been reading this thread, is it right that the protrack charges the whole pack (i.e a normal serial charger) and ONLY monitors each cell. so its not an ICC?
magm20001 is offline
Old 12-07-2007, 06:58 PM
  #515
JayBee's Avatar
Trader Rating: 31 (100%+)
FEI (for everyone's info)- I have a Mint condition ProTrak if you're in the market for one I have to hook it up to see how far it's been upgraded...
JayBee is offline
Old 12-08-2007, 12:55 AM
  #516
Correct.
In peak detect it stops charge @ whatever millivolts the user has set for the pack and in temp detect it stops @ the 1st cell to reach whatever temp cut-off the user has set. But all the other chargers out there on the market do the same.
In discharge mode with the remote leads on the cells it will stop the discharge for the 1st cell to reach 0.5v nomatter what cut-off voltage is selected. The ICC is able to carry on it's discharge till all cells are empty.
1st pic is 3700's on Pro-Trak.
2nd pic is same pic finished off on the ICC.
Attached Thumbnails Pro Trak-cell-4-stops-discharge.jpg   Pro Trak-3700-pack-2-cell-4-stopped-discharge-then-spintec.jpg
Old 12-08-2007, 11:03 AM
  #517
magm20001's Avatar
thanks champ
Old 05-11-2008, 11:19 AM
  #518
Default Pro Trak & TrakPower V-Balance module for LIpos's
I tried to use the TrakPower V balance module with my ProTrak but received an error message when I tried to charge.
Has anyone else had a similar problem and is there a way round it or will I need a different charger?
The ProTrak charges fine without the V Balance module in line
CamR is offline
Old 05-12-2008, 03:18 AM
  #519
Post a picture if you can of the error message
I'll try my V Balance on my Pro-Trak / LiPo cells and see if I get the same message
Old 05-16-2008, 12:55 AM
  #520
It's sorted now. I was not placing the V-Balancer into Link mode
CamR is offline
Old 11-09-2009, 07:33 AM
  #521
CFR
CFR's Avatar
wakey wakey
time this thread had a reboot
+ YouTube Video
CFR is offline
Old 07-13-2019, 05:07 PM
  #522
Hi
Does any one have the wiring diragran to make a balance lead to connect to the cells?
Smoking motor.. is offline
Old 07-13-2019, 06:16 PM
  #523
kiyano's Avatar
see
http://www.kimihiko-yano.jp/WS00522.JPG
kiyano is offline
Old 07-14-2019, 01:12 AM
  #524
Originally Posted by kiyano
Thanks has anyone got any information on the max charge amp it can do I hace 12.37 20D software program on it the current power supply willonly out 12amps so max charge is 12amps on lipo.
Old 07-14-2019, 02:08 AM
  #525
kiyano's Avatar
Setting in the calibration table 42 to 1 can increase the charge current to 15A. But for this you need to check the following
1. The lifetime of the charge FET will be shorter than at 12A
2. The 20A version of PRO-TRAK has poor heat sink cooling capability. So you may need external fan cooling
3. When PRO-TRAK is shipped, it is adjusted for 12A charge current. Even if Software allows charging current up to 15A, the current may not actually increase up to 15A. In that case, it is necessary to readjust PRO-TRAK
kiyano is offline
