Yokomo R12
#646
TN Racing conversion kit for Jaco rims (TN-958) was built for the original R12 rear pod which is a different width than the current R12C variants (made the mistake of ordering it awhile back only to realize the difference). For the IRS axle Just look up the parts for the AE 5.2 and that works. Pick up the Top 2mm axle shims unless you want a bunch of .5mm shims (see previous post). Besides being able to run more available tires in the US the AE axle also shaves 10g off for those having issues with the weight. I'm also getting another batch of Yokomo rims mounted with BSR blue/double blue fronts and green/blue rears so shoot me a PM if you need any (the yellow rims are sweet).
#648
#650
#652
On another note, all the US drivers looking for some great quality tires. Pro-One Race tires will have Yokomo compatible hubs in the next couple weeks. That will open up the full line of Pro-One rubber readily available.
https://www.facebook.com/ProOneRc/ph...type=1&fref=nf
#653
That's what I'm running with no problems
Send a few of those hubs over to Japan! Many drivers are running the Yokomo chassis and would benefit from using these hubs.
#654
Anyone interested can send an e-mail to [email protected]
Steve Dunn
Pr oOne R/C
#655
Iv just brought a r12c3, Other then converting it to 3.1 style side dampers is there any other normal modifications people do?
#657
Being that I cant read Japanese...
Could someone tell me which upper control arm mount is kit setting, The one marked H or 0.5mm?
Matthew
Matthew
#659
http://www.redrc.net/2015/02/2015-ma...m-race-report/
great win from yokomo team driver daniel sieber against markus mobers and other good european drivers.
https://www.facebook.com/teamyokomo
https://www.facebook.com/teamyokomo/...28087063868511
setup:
http://www.petitrc.com/reglages/yoko...r_Mol20150201/
setup:
#660
Ready to run
