Yokomo R12
#407
#408
Rear bearing offset
Hi,
I noticed that for Yokomo R12, the maximum bearing offset in the rear is 1.75mm.
So for brand new tyre, with the maximum bearing offset, the ride height is still of a high ~6.5mm.
Where else I can get bearing offset for Associated up to 3.5mm. But again, the rear bulkhead is different and I can't use the Associated bearing offset on R12.
Does anyone got a better solution to reduce the ride height for brand new tyre ? err... beside cutting them ?
Many thanks.
Many thanks.
#410
The front is very adjusable and plays a big role on the cars whole entire handling characterisitcs but my only complaint is the use of e-clips. the plastics are very soft but i prefer some flex but I heard that the plastic are so soft it causes the shock the leak. I haven't had issues cause I use green slime and thick oil. The front axles are the same as any other 1/12 but the rear is only slightly different. in order to use wheel that are currently on the market you will need to change out the axle and hub and some shims. the Yokomo hubs create the wide wheel base so their wheels are deep dish style as for the parmas, crc, ect wheels are flat so if you use those wheels on the yoke hub it will give you a crazy wide wheelbase!
#411
Hello,
Does anyone have R12 Setup sheet to share form the last worlds?
#413
All things 12th scale from....
http://www.rctech.net/forum/californ...ll-so-cal.html
#414
http://www.petitrc.com/reglages/yoko...YokomoR12.html
PetitRC's link is broken.
#416
help
Which most economical solution for rear tires off normal set of Yokomo r12?
which parts are needed?
#419
#420
