Like Tree4Likes
Yokomo R12
Old 08-24-2010, 07:48 AM
  #181
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Goingfast
Hi hotdognobun
I know it is kind of late but ,You can use any 12th axles assy. it will works on R12 ....
Thats good stuff! Thx
hotdognobun is offline
Old 08-24-2010, 10:03 AM
  #182
corallyman's Avatar
Trader Rating: 101 (100%+)
Originally Posted by RedBullFiXX
I'm old school
Don't mind mounting tires at all
Still have to do it with the F1 cars, no problem doing it for 12th scale.
Also, I have a feeling that the Yokomo Axle, wheels and hubs are going to be more precise than the AE / Jaco parts
Could not agree more, mounting and trueing tires is actually kind of fun if you know how to do it easily It also re connects us to the old school days, which is good too.
Steve
corallyman is offline
Old 08-24-2010, 10:16 AM
  #183
Steve
Ok then I'll send you all my Yoke rims and foam so you can mount them for me! .....please
Old 08-24-2010, 10:40 AM
  #184
corallyman's Avatar
Look around your local hobby shop to see if they stock a CA type glue called Slow Jet, if they do, then I will.
Steve
Old 08-24-2010, 10:52 AM
  #185
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Steve
Slow Jet ?? who sell them here?
OVA is offline
Old 08-24-2010, 10:57 AM
  #186
Steve
I've mounted foam before but never got the hang of it. Always turns out bad so i'm just wasting glue, wheels, and foam. Any advise or sites that shows how to do it? THX
OVA: Tower hobbies sell Slow Jet Glue
http://www3.towerhobbies.com/cgi-bin...?&I=LXNXC6&P=M and have you switched the r5.1 rear axle to the r12?
Old 08-24-2010, 11:03 AM
  #187
corallyman's Avatar
Its all in the glue, my friend. Seriously some glues dries so quickly you don't have time to realign the tire or its so thin it runs all over the place. That is why I only recommend slow jet. Jet is the brand and slow is the type of glue, I think there are 3 different types of thicknesses. It gives you about 3 minutes or so before things get serious and that is long enough to do it properly. In years past I have been able to then true the tires in about 1 to 2 hours after gluing but you should leave over night to be safe.
There may be other glues to use but I have not used them but slow jet is awesome for this. For normal use I use the faster CA's
Steve
Old 08-24-2010, 11:04 AM
  #188
corallyman's Avatar
That's it.
Old 08-24-2010, 11:36 AM
  #189
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I use rubber cement.
Like this
RedBullFiXX is offline
Old 08-24-2010, 01:41 PM
  #190
Like this
I'm with you, Dave!
I use rubber or contact cement as it not only provides excellent adhesion, it also has some give. I think that the new mounted wheels and tires chunk and more precisely, tear easier because they are now using CA type of glue. I have noticed that after an 8 minute run and not hitting anything, the foam will tear away from wheel due to the heavy side loading during cornering. You can see a thin layer of foam still stuck to the wheel and the rest of the foam is tearing away. I think it's because the CA glue soaks into the foam making the foam where the CA soaks in, brittle and therefore, it tears at the point where the CA stopped soaking into the foam. I have never used CA to glue foam and maybe the flexible CA might work better but I will always use contact cement.
Crashby is offline
Old 08-25-2010, 01:38 AM
  #191
Me_MrTyson's Avatar
Trader Rating: 11 (100%+)
Front Shock Spring.
Having built the r12 decided to see what happens with the front spring installed the one from the kit.
Does anybody know what this will do? just in case I smash the car on the first outing because of it
Running outdoor track not carpet
Me_MrTyson is offline
Old 08-25-2010, 02:02 AM
  #192
Originally Posted by Me_MrTyson
Front Shock Spring.
I actually deciding to use the front shock spring and remove the small front side springs. My other R12 had this set up and I felt more in control because it absorbs bumps and keeps the front planted to the ground so I have always prfered the set up. Here is my other r12 suspension set up. Damaged my carpet spec one so I am in the middle of transfering the electronics to my back up
Old 08-25-2010, 02:59 AM
  #193
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
What shock springs are they?
Yokomo_Ant3 is offline
Old 08-25-2010, 03:34 AM
  #194
Hive springs... got them from windtunnel racing
http://www.windtunnelracingproducts....p?cPath=42_202
Old 08-25-2010, 03:39 AM
  #195
mike ivy's Avatar
Trader Rating: 51 (100%+)
Anyone know if Yokomo is just going to sell there front end?
mike ivy is offline
