Your thoughts on reduced throttle EPA settings
adjustable rate control does the same thing. If you set it on the high side the throtle will not move until the trigger is half way through it's motion. Set it on the low side and the throtle stops half way throught the trigger pull. that is how it is on a m11 anyway
If you set it on the high side and pull the trigger half way, what does the servo do? Does it jump to the half way point quickly or does it start at the bottom of the range? In other words, does half trigger mean half throttle or the begining of the range?
