Spec-R Gear diff review
#706
Hi there,
Can the TCX gear diff fit the TC?
Also, can the TA05 gear diff fit the 501X buggy?
Thanks.
Thanks.
#708
#709
k4mp4q, The FF03 Champion at TITC was running 300K[/QUOTE]
Ok thanks, but ff03 on titc were using brusless motor, will it be the same since i'm goin to use tamiya lightly tune brush motor...
#716
#717
#718
Hi there. Looking to order for my t3. New to EP.
Any suggestions for setup?
Do I run in both front and rear? Or just one or the other?
Thanks.
Thanks.
#719
Geez its hard to keep the oil from leaking on my spec r put Silicon on it and its still leaking at the pulley.. what are some of the sure fire ways to keep this thing from leaking.. from the pulley.
I have not put too much oil in it.. its kinda thick well for the rear.. 2000K..
The silicone set and when turning each end with my hands its leaking.. bloody thing. not leaking as much as with no silicone but still leaks..
It seems a bit hit and miss.. some ppl are saying they just put the thing together no silicone no sanding and no leaks.. WTF. wish I was in that boat.. the amount of times I have built this to get it right and not leak is crazy..
I know they leak a little.. like my NT1 but this is too much leaking.
#720
All my Spec-R geardiffs are almost not leaking at all. I sand the back of the gears (all of them), and when I tighten the screws, I do it in a cross-pattern, in order to get the pulley down evenly. I noticed the first time (when not cross-tightening) that the pulley wasn't sitting evenly.
