Spec-R Gear diff review >
Old 10-17-2010, 01:52 PM
  #586
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by mac853
Could you tell me if these CST and WT are same unit, if comparing with Kyosho and Mugen ones, they are the same comparison?
And i think shock oil and 350 are so low, isn't it?
Best regards
don't do WT to WT comparisons. you can compare CST to CST though.
the rear diff fluid only needs to be think enough to not diff-out. when running outdoors on medium to high grip asphalt i was able to run a very think oil. the did my outdoor testing at Jackson RC, home of the 2011 ROAR On-Road Asphalt Nats.
when going indoors you need a thicker oil to prevent the car from diffing out.
hanulec is offline
Old 10-17-2010, 05:57 PM
  #587
robk's Avatar
Trader Rating: 22 (100%+)
I finally got 500K diff oil and the front diff in my car. This is awesome. On carpet, it eliminates the herky jerk that comes with a spool, but still pulls out of the corner. The car is butter smooth.
robk is offline
Old 10-18-2010, 12:36 AM
  #588
mac853's Avatar
Questions??
OK, i appreciate your explain, but could you tell me as well what brand of oil are you using it, please?
I just want to have the same ones as you just for comparing easily.
Best regards
mac853 is offline
Old 10-18-2010, 12:43 AM
  #589
Trader Rating: 88 (100%+)
here you go mac,
Outdoors I was using XRay shock oil. I ran 350cst outdoors.
Indoors on carpet I'm now using Mugen diff oil because it is availabld in closer cst ranges. I'm currently testing with 3000cst.
joey is offline
Old 10-18-2010, 12:55 AM
  #590
mac853's Avatar
Lightbulb
Originally Posted by joey
here you go mac,
Oh, i didn't note that, thanks!
mac853 is offline
Old 10-18-2010, 01:53 AM
  #591
RCknight's Avatar
Robk do you race VTA? Just wondered if it 500 would be good in VTA? I have no clue where to start with oil for a front gear diff only in T3.
RCknight is offline
Old 10-18-2010, 06:35 AM
  #592
M-Technic's Avatar
Trader Rating: 15 (100%+)
Start with 100,000 and then go thicker... up to 300,000 probably.
M-Technic is offline
Old 10-18-2010, 09:02 AM
  #593
robk's Avatar
I don't see why it would not work in VTA. I'm going for a front diff that acts like a spool but is not so violent on and off power. Should work the same in a VTA car.
robk is offline
Old 10-18-2010, 02:53 PM
  #594
KELVIN KHNG's Avatar
Guys..
I have just gotten the spec R diff and I must say they really look awesome... What diff oil would you recommend on the rear diff of a 416 for stock rubber carpet racing?
KELVIN KHNG is offline
Old 10-18-2010, 09:41 PM
  #595
robk's Avatar
Originally Posted by KELVIN KHNG
Guys..
2000 or 3000 would be a good starting point.
robk is offline
Old 10-18-2010, 10:53 PM
  #596
kcunamay's Avatar
Trader Rating: 20 (100%+)
I raced with the SPEC R diffs in my T3 this weekend with the new o rings. XRAY 100K CST Front and 1K Rear. NO LEAKS and as smooth as a new ball diff. Outdoor high traction asphalt.
NO MORE broken spool drive cups, and it still pulls hard out of the corners.
I WILL NEVER go back to rebuilding ball diffs again.
kcunamay is offline
Old 10-18-2010, 11:11 PM
  #597
hanulec's Avatar
nice, right. i'd recommend you try some lighter oil in your rear diff next time out. you'll find the car will rotate even better through corners.
hanulec is offline
Old 10-19-2010, 12:18 AM
  #598
RCknight's Avatar
Robk, do you have a link where to buy the 300,000? What brand is it? I'll try this in the front gear diff in VTA. The track has low-med. traction. If that don't work I'll try the 200000.
RCknight is offline
Old 10-19-2010, 09:01 AM
  #599
robk's Avatar
I was recommending 2000 or 3000 wt for the rear, not 200,000 or 300,000 wt. I use 500,000 Traxxas oil in the front of my car. It's easy to get since it's for a Revo
robk is offline
Old 10-19-2010, 09:08 AM
  #600
Trader Rating: 12 (100%+)
Can someone be kind enough to post a link where I can purchase the new o-rings, seals and gaskets?
Thanks in advance!
Turillo is offline
