Spec-R Gear diff review
#241
#242
I initially built it with a small shim on both sides. After a run or two, it felt like the shims were binding up the gear mesh a little bit. I took them out and ran in in the stock configuration with a 4.5, 5.0. and boosted 6.5. The gear mesh on mine is very tight- even with the stock shims.
#244
Been running my w/a 4.5 on several differnent tracks for a month now w/no problems.
However, I have spent a considerable amount of time on my bench messing around with it.
FYI: I've found the easiest and (so far) best way of bullet proofing the diff is to just add longer pins to the stub axles ( to lock in the gears).
Just 1mm longer will work. This keeps the pins from entering the recess for the orings.
The only trick is to use a sharp Xacto knife to remove .5mm of mat. from both ends of the pin slot on the gears.
#245
Thanks.
#246
#247
Just a quick question...
How do you go about ordering online? I couldn't see on the website where to order directly?
luke
luke
#249
Hobson, Got mine from EGR mart. Worked out at £34 pounds all together with a spare gear set and spare gasket set and delivered to the UK...
I think its possible to use an extra shim when an extra gasket is used, i cant see why you would though. Mines been fine as standard so far.
#250
Yeah I looked on there but out of stock for the 416 version.. Typical lol
cheers tho johnny
cheers tho johnny
#251
het luke i orderd mine from ks hobby on monday and the website there was 1 left in stock after my order.
#252
SPEC.r in UK
Luke,
try
demonpowerproducts.co.uk
try
#253
Hi don
I checked demon first, they only stock the xray version, seems nowhere has the tamiya version
